What Is the Velocity of the 3 kg Fragment After Explosion?
The discussion focuses on calculating the velocity of a 3 kg fragment after an explosion of a projectile at its peak trajectory. The initial conditions include a 5 kg projectile fired at 80 m/s at a 75° angle, which explodes into two fragments of 3 kg and 2 kg. The 2 kg fragment lands directly below the explosion point 2.5 seconds later, allowing for calculations of its velocity and the subsequent velocity of the 3 kg fragment. The conservation of momentum principle is emphasized, noting that the total momentum before the explosion must equal the total momentum after. The calculations involve determining the velocity components of both fragments to solve for the magnitude of the 3 kg fragment's velocity and the energy released during the explosion.
blayman5
A projectile of mass 5 kg is fired with an
initial speed of 80 m/s at an angle of 75◦ with
the horizontal. At the top of its trajectory,
the projectile explodes into two fragments of
masses 3 kg and 2 kg . The 2 kg fragment
lands on the ground directly below the point
of explosion 2.5 s after the explosion.
The acceleration of gravity is 9.81 m/s2 .
Find the magnitude of the velocity of the
3 kg fragment immediatedly after the explo-
sion. Answer in units of m/s.
Find the distance between the point of firing
and the point at which the 3 kg fragment
strikes the ground. Answer in units of km.
How much energy was released in the explo-
sion? Answer in units of kJ.
~pi = ~pf
m1 ~v1 = m2 ~v2 + m3 ~v3
m1 v1^{ = m2 vx2^i + m2 vy2 ^j ¡ m3 vy3 ^j
Vx=m1/m2 (VcosO)
Y=(vsin0)^2/(2*9.8)
Vy3=(y-(1/2)(g)(t^2))/2.5
Vy2=m3/m2(Vy3)
sqrt(Vx2^2+Vy2^2)
magnitude V2x=80.7314m/s
Where did i go wrong?
Well you know the momentum before must equal the momentum afterwards. Since the projectile is at the top of its trajectory when it explodes it has no vertical component of momentum at the particular time. What you need to do is find the velocity of the 2Kg fragment which will help you find the components of the other fragment. Remember the vector sum before must equal the vector sum afterwards.
