Projectile motion homework help
Gravity is consistently treated as negative in projectile motion calculations because it always acts downward, which is conventionally represented by a negative sign in the coordinate system. This approach simplifies the analysis of motion, as the direction of acceleration due to gravity remains constant throughout the projectile's flight. While the object decelerates on the way up and accelerates on the way down, the sign of gravity does not change; it always indicates the downward direction. The confusion arises from equating negative acceleration with deceleration, but the negative sign simply denotes direction. Understanding this concept clarifies why gravity is consistently applied as -9.81 m/s² in calculations for time of flight.
nirvana1990
Why is gravity always taken as negaive when applied to the whole projectile i.e. when finding the time of flight for the entire projectile we use gravity as -9.8 even though it is only negative for the first half of the projectile while the object is moving upwards against gravity?
Please help as i am very confused!
:rolleyes:
Mathematics news on Phys.org
Its just a convention. Positive speed and positive acceleration tell us that it is directed upwards whereas negative speed and negative acceleration indicate a downward motion. it would work just as well the other way around if a little counter intuitive.
Welcome to PF!
I'm not sure what you mean by that.
Remember Newton's second law? It says that direction of the force and acceleration are the same. At all times during the motion of the projectile the direction of the force of gravity (we assume a uniform gravitational field) always points down, towards the ground. Also, for convenience, we usually set up the coordinate system such that the negative y-axis points in this direction. Therefore the gravitational force, F_g = -mg\hat{y}.
Right...but since gravity always acts downwards, the acceleration for the 1st half of the projectile motion should be -9.81 since the object is decelerating towards its max. height but the acceleration for the downwards projectile motion (e.g.when the ball is on it's way back down to earth) should be +9.81 since the ball is accelerating. So when calculating the time of flight using S=Ut+0.5at^2 applied to the vertical motion only why do we use a as -9.81 even though a should only be negative while the ball is going upwards?
I hope this is understandable! i have a way with words!
The acceleration is always downwards. In the coordinate system that is conventional downwards is represented by a negative sign. The sign doesn't change once the projectile starts falling to Earth.
I think you are confusing a negative sign to mean deceleration and a positive to mean acceleration and that is just not the case. The sign indicates the direction of the acceleration.
For a body accelerating towards the ground, the equation would actually read,
s = h_{max} + ut + \frac{1}{2}at^2
u = 0, therefore s - h_{max} = \frac{1}{2}at^2. Is s - h_{max} positive or negative?
Oh i see, i'd never have thought of it like that! Thank you soo much! I can now rest!
That's true. When the direction of the velocity and acceleration are opposite, then the body is slowing down, or decelerating.
