For (c), at max height, v=0, so use v2 = u2 + 2as, just put u=20, a=-9.81, s=54
The discussion focuses on solving a physics problem involving a stone thrown vertically from a height. For part (a), the user calculates the time to reach the maximum height and then the time to reach 40 m/s, arriving at a total time of approximately 6.04 seconds. In part (b), they determine the final velocity before the stone hits the ground using the wrong distance but are guided to use the correct formula with adjusted values. For part (c), the user correctly identifies the acceleration at maximum height as 9.8 m/s². Overall, the responses highlight the importance of using the correct equations and values for accurate calculations.
madinsane
a man throws a stone vertically upward with initial speed of 20 m/s from a building with height 54 m a)how long does the stone take to reach 40 m/s
b)what is its velocity before it reaches the ground
c) what is the magnitude of its acceleration at its maximum height?
vf=vi+at
xf=xi+vit+0.5at
vf^2=vi^2+2a(xf-xi)
I just want someone to tell me whether what I have done is right or wrong
so for a)
I took vi=20m/s
vf=0m/s (I was going to calculate how long it takes to reach the maximum peak)
then I used vf=vi+at (a as-9.8)
I got 2.04 s
Then I took vi=0
vf=40
then used the same thing and got t as ~4 and then I added them together
b) At first I calculated the distance it takes to go from the building to the peak
using xf=xi+vit+0.5at
xi=0
vi=20
t=2.04
a=-9.8
I got ~22m
Then I added to the 54
then I used vf^2=vi^2+2a(xf-xi)
vi=0
a=-9.8
xf=76
xi=0
and got vfinal
c) I said it was 9.8 m/s^2
So did I do anything wrong and if I did tell me what it is
You're correct, but it can be done simpler
For (a), v = u + at, just put v=-40, u=20, a=-9.81
For (b), v2 = u2 + 2as, just put u=20, a=-9.81, s=-54
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
