Projectile Motion involving eletric fields
The discussion revolves around solving a projectile motion problem involving protons in a uniform electric field. The key challenge is to find the two projection angles and corresponding times of flight for protons projected at an initial speed of 9.89x10^3 m/s to hit a target 1.27 mm away. Participants suggest decomposing the motion into horizontal and vertical components, using kinematic equations to relate distance, velocity, and acceleration. The equations involve eliminating time to find the angles, but confusion arises regarding the correct application of trigonometric identities and the quadratic formula. Ultimately, the goal is to derive a single equation with one unknown to solve for the angles effectively.
SF2K4
Ok, so, I've about had it rattling my brain on this. I'm stumped.
Q:
Protons are projected with an initial speed vi = 9.89x10^3 m/s into a region where a uniform electric field E = (-720 j) N/C is present. The protons are to hit a target that lies at a horizontal distance of 1.27 mm from the point where the protons cross the plane and enter the electric field.
Find the two projection angles that result in a hit and the corresponding times of flight.
The only thing I was able to compute (hopefully I got it right) was that the acceleration in the y-direction (as there is none in the x) is -6.89687x10^10 m/s^s. Since E is -720j and knowing the charge and mass of a proton I calculated that... but that's about all I've got.
I know all of my kinematic equations but I'm still at a loss on this problem...
Think
What is the the net vertical distance traveled by the proton before hitting the target?
Will this help to find time elepsed?
What is the horizontal distance traveled during this time?
The horizontal distance is 1.27mm... but there are two vertical distances depending on the angle theta...
decompose the problem into x and y direction... write down the equation of motion in terms
of the angle theta and time t...
For the x direction, the distance travel is 1.27mm... v_x depend on the angle theta and the
projection velocity... it is easy, you should have no problem on this one...
For the y direction, vertical distance travel is zero... right?
Now you have two equation with two unknown...
The equations I have are:
dx = vxit
vyf = vyi + at
dy = vyit + (1/2)at^2
However, t is unknown and vyi and vxi are all dependent on theta...
so, you have
d_x = v_x^i t
d_y = v_y^i t + \frac{1}{2} at^2
and from the relationship
v_x^i = v^i cos\theta
v_y^i = v^i sin\theta
The only unknown(s) are t and \theta
Could you solve for \theta by eliminating t??
But then wouldn't I be left with something like:
d_x = v^i cos\theta t
Which would result in:
t = \frac{d_x}{v^i cos\theta}
And after using sin^2\theta + cos^2\theta = 1 I should be able to use a quadratic formula to get two values of t... but I only end up getting one and it doesn't result in a correct answer.
Why would you use sin^2\theta + cos^2\theta = 1 ?
since you know t = \frac{d_x}{v^i cos\theta}, just plug it into
d_y = v^i sin\theta t + \frac{1}{2} at^2
with the t eliminated, now you are left with one equation with one unknown...
Everything shall be crystal clear from here, right?
