Projectile Motion of broad jumper
The discussion focuses on calculating the horizontal velocity and displacement of a broad jumper who takes off at a 22-degree angle and reaches a height of 70 cm. The calculated horizontal velocity is 9.16 m/s, and the jumper's vertical motion is analyzed using trigonometric functions and kinematic equations. There is some confusion regarding the definition of "horizontal displacement," with participants debating whether it refers to the distance at the highest point or where the jumper lands. The time to reach the peak height is calculated as 2.3 seconds, but there is uncertainty about how to proceed from this point to find the total horizontal displacement. Clarification on these concepts is necessary for accurate problem-solving.
SigFig
A broad jumper begins his jump at an angle of 22 degrees from the horizontal. At the middle of the jump he reaches a height of 70.0cm
a. What is his horizontal velocity
b. What is his horizontal displacement
ANSWER: 9.16m/s
dh=vht
dv=1/2at^2
t=vv/a
Sin 22 = x/70 x= 26.2
26.2=1/2(9.8)t^2
√t
t= 2.3sec
Since it's half way up, you'd have to double the time to find the entire time(?) needed for the entire horizontal displacement, but I have no clue what to do after getting time (if that's even right).
ANSWER: 9.16m/s
dh=vht
dv=1/2at^2
t=vv/a
No, the angle is his initial trajectory. It does not provide a straight line to his highest point.
What vertical component of speed would he need at take-off to reach that height?
What, therefore, was his horizontal speed?
Btw, it's not clear to me whether "horizontal displacement" refers to where he lands or at the highest point. I think it's the highest point.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
