Projectile Motion Questions: Solving for Height, Velocity, and Time
The discussion revolves around a projectile motion problem involving a can being released from a balloon. Participants are tasked with calculating the height of the basket, the can's vertical velocity upon release, the time until it hits the ground, and the timing of the can's fall relative to the basket.
  • Participants explore the implications of constant speed for the balloon and question the assumptions regarding the height from which the can is released. There is discussion about the calculations for time and velocity, with some participants suggesting reevaluation of initial conditions and calculations.
There is an ongoing exploration of the problem with various interpretations being discussed. Some participants have offered corrections and suggestions for recalculating values, while others have acknowledged mistakes in their previous calculations. The dialogue indicates a collaborative effort to clarify concepts and assumptions without reaching a definitive conclusion.
Participants are working with specific values and assumptions, such as the acceleration due to gravity and the initial conditions of the can's motion. There is a noted uncertainty regarding the height of the basket and the timing of events, which remains under discussion.
member2357
The information required is in this picture: http://i.imgur.com/Dt7F9pg.png
There are four questions based on what is in the picture.
The questions are:
1) Calculate how high above the ground the floor of the basket is before the can falls out of the basket.
2) Determine the vertical component of the can's velocity as it leaves the basket.
3) Find the time it takes for the can to hit the gouned after it leaves the basket.
4) Find the time that elapses between the basket touching the ground and the can.
Projectile motion equations:
Vertically:
[tex]\ddot{y}=a[/tex]
[tex]\frac{d\dot{y}}{dt}=a\therefore \int d\dot{y}=\int adt\therefore \dot{y}=u\sin\theta +at[/tex]
[tex]\frac{dy}{dt}=u\sin\theta +at\therefore \int dy=\int \left ( u\sin\theta +at \right )dt\therefore y=u\sin\theta t+\frac{a}{2}t^{2}[/tex]
Horizontally:
[tex]\ddot{x}=0[/tex]
[tex]\frac{d\dot{x}}{dt}=0\therefore \int d\dot{x}=\int 0dt\therefore \dot{x}=u\cos\theta[/tex]
[tex]\frac{dx}{dt}=u\cos\theta\therefore x=u\cos\theta t[/tex]
1) ??
2) 3 m/s
3) 0.612
4) The same time?
1. The balloon has constant speed. So where is it 10s before it hits the ground.
2. Right
3. How did you find that if you didn't know how high was it when released? You should better consider it again. (It is also wrong)
4. Nope... The basket continues falling in the same speed as before. The can is on free fall with initial speed.
I suggest you make good schematics for every phase of the procedure and the forces involved on the can
I thought the balloon's velocity would be increasing because of gravity but the question says it is constant. Does that mean the height would be 30 m?
For question 3, the answer would become 2.86 s if the height the can is released at is 30 m.
For number 4, the can would hit the ground first and after 7.14s the balloon would hit it, right?
"For question 3, the answer would become 2.86 s if the height the can is released at is 30 m."
Check your calculations here. g = 9,81 right? you aree close
I just recalculated it and got 2.8. Don't know how I got it wrong the first time.
Thank you!
You are correct. I forgot about the initial vertical component of the can.
  • · Replies 18 ·
  • · Replies 24 ·
  • · Replies 21 ·
