Projectile problem without theta or time
The discussion centers on a projectile problem involving a cannon that must explode 10 meters above a target located 1000 meters away, with an initial velocity of 10 m/s. Participants note that the given parameters are inconsistent, as a projectile fired at that speed cannot reach the required distance of 1000 meters. The need for additional information, such as the angle of launch or time of flight, is emphasized. The conversation highlights the importance of accurate problem statements in physics. Overall, the problem as presented lacks sufficient data for a valid solution.
pwoolson
shooting a cannon so that it explodes 10m off the ground above a target. The distance of the target is 1000m. Cannon is shot with a velocity of 10 m/s. Solve a) for θ and b)time in the air
I guess you are forgetting something...
Comment:
A projectile that is fired from the ground with an initial velocity of 10 m/sec will not travel 1000 m. Something is wrong with the problem statement.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
