Projection motion on a slope; f angles that will provide the greastest range
The discussion revolves around a projectile motion problem involving a boy throwing a rock from the peak of a hill. The goal is to determine the optimal angle for the throw to achieve the greatest distance traveled by the rock, considering the slope of the hill and the angles involved.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the setup of the problem, including the angles involved and the use of kinematic equations. There are attempts to manipulate equations related to projectile motion and questions about the clarity of the angle definitions.
Some participants are exploring different approaches to solve the problem, including changing the coordinate system to align with the slope. There is a mix of attempts to derive equations and requests for clarification on the angles involved.
Participants note potential confusion regarding the angles provided in the problem statement and the implications of those angles on the projectile's motion. There is also mention of the complexity involved in deriving the necessary equations.
sarah08
A boy is standing on the peak of a hill (downhill), and throws a rock, at what angle from himself to the horizontal should he throw the rock in order for it to travel the greatest distance.
Answer clues:
1. if, the angle from the slope to the horizontal = 60, then the angle from the horizontal to the boy =15
2. the angle is not 45 degrees
vf^2 = vo^2 + 2ad
sin2(theta) = 1
cos^2(theta) + sin^2(theta) = 1
I tried to solve this by changing the axis so that the slope is the x axis, and then solving using the first kinematic equation above, i finally ended up solving for vo, which was ( 1+ 2cos(theta) + sin 2(theta) )/2...i doubt that is right though, I just don't know how to put all of this together!
some help would be appreciated
Hi Sarah, welcome to the Physics Forum!
Interesting problem, but I can't wrap my mind around this
This makes no sense to me - could there be a typo?
no its not a typo..there are two unknown angles, and the clue was that the slope of the hill, or the angle from the slope to the horizontal is 60, then, the angle above that, or the angle between the boy and the horizontal would be 15...i attached a little drawing i made, hope that helps!
I think I solved it. Tough problem. I created 4 equations. The first too were just the x and y positions. The next was for the total distance using the Pythagorean theorem. The final was from realizing that when the object will land, it's ratio of y to x pos will be equal to the tan of the slope (draw a picture).
After that it just takes a whole lot of manipulation so that you can finally take the derivative and set that equal to zero.
could you post the four equations you came up with, and i can try to manipulate them myself and see if i can do it?
thank youu
[tex]x = v_ocos\theta _2 t[/tex]
[tex]y = v_osin\theta _2 t -\frac{1}{2}gt^2[/tex]
[tex]d=\sqrt{x^2+y^2}[/tex]
[tex]tan\theta _1 = y/x[/tex]
Manipulation + derivation is a long process. ><
do you think it would be easier to solve if you tilted the axis so the x-axis is parallel to the slope?
  • · Replies 20 ·
