Prolonged contact between HCl and alkanes
Hydrochloric acid (HCl) does not react with simple alkanes (C4-C12) over short timescales, as they separate with HCl settling at the bottom and hydrocarbons floating on top without any noticeable heating or property changes. The discussion raises the possibility of reactions occurring over longer periods, such as hours to weeks, in a closed polyethylene container with pressure release but no inert gas purging. No specific reactions are anticipated, but the inquiry seeks to ensure that no significant reactions are overlooked. Additionally, the potential suppression of HCl outgassing by the layer of hydrocarbons is questioned, comparing it to how water evaporation is hindered beneath oil. It is suggested that nucleophilic substitutions may occur for branched alkanes when n > 3, but the overall impact on outgassing rates remains uncertain.
KarenRei
I've verified that there is no obvious reaction between hydrochloric acid and simple alkanes (roughly C4-C12) over short timescales; they simply settle out with the heavier HCl on the bottom and the lighter hydrocarbons on the top, with no apparent heating or changes in general properties (as anticipated). However, are there any reactions on the scale of hours to weeks or more, if the solution were stored (closed polyethylene container, pressure release, not purged with an inert gas)? Nothing comes to mind, but I'm just wanting to make sure I'm not missing anything.
Also, would the expected rate of outgassing from the HCl be suppressed by having a layer of hydrocarbons on top of it (as water evaporation is hindered beneath a layer of oil), or would it remain pretty much unchanged?
Nucleophilic substitutions of branched members of families for n > 3 can be expected.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
