Proof Ideal Gas: (dU/dV)T=0 & (dH/dP)T=0
The discussion focuses on proving the equations (dU/dV)T=0 and (dH/dP)T=0 for an ideal gas. It is established that the internal energy (U) of an ideal gas is solely a function of temperature (T), leading to the conclusion that the change in internal energy with respect to volume at constant temperature is zero. Similarly, the enthalpy (H), defined as H = U + PV, also depends only on temperature when using the ideal gas equation, resulting in (dH/dP)T=0. The moderator's warning indicates that the discussion strayed from academic norms.
  • Understanding of thermodynamic concepts such as internal energy and enthalpy.
  • Familiarity with the ideal gas law and its implications.
  • Knowledge of partial derivatives in thermodynamics.
  • Basic principles of constant temperature processes.
  • Study the derivation of the ideal gas law and its applications.
  • Learn about the relationship between internal energy and temperature for different substances.
  • Explore the concept of enthalpy and its significance in thermodynamic processes.
  • Investigate the implications of constant temperature processes in thermodynamics.
This discussion is beneficial for students and professionals in thermodynamics, particularly those studying ideal gas behavior, internal energy, and enthalpy relationships in physical chemistry or engineering contexts.
Hong1111
How to prove that
(a)(dU/dV)T=0
(b)(dH/dP)T=0
for an ideal gas.
Where U is internal energy per unit mass, V is volume, T is temperature (which is held constant for above 2 question), H is the enthalpy per unit mass, and P is the pressure.
I found this in a thermodynamics textbook. This is not a homework question. I just want to know how does this apply to ideal gas and how to derive the both equations. And in the end, I got warning from moderator.
Thanks.
For an ideal gas you should find that the internal energy is only a function of T, hence dU/dV is definitely zero.
Same applies for the enthalpy, define H = U + PV, use the ideal gas equation to substitute for PV and you'll see that H is only a function of T as well, so dH/dP is zero.
I don't see the point of those equations though =/
