Proving Twice Differentiability at a Point for a Function of Two Variables
nuuskur
Given f(x,y) = x\cdot 3^{x+y^2}. Prove that f is differentiable twice at the point P(1,0).
D\subset\mathbb{R}^2, f\colon D\to\mathbb{R}, P\in \mathring{D}(interior point) - then f is differentiable n+1 times at P\Leftrightarrow \exists\varepsilon > 0\colon in the sphere B(P,\varepsilon) there are defined n-th degree partial derivatives.
I want to use the definition of a partial derivative f_x := \lim_{t\to 0}\frac{f(P_x + t, P_y) - f(P_x,P_y)}{t} if the limit exists (either in R or +/- infinity).
How can I check if the limit exists for any and all points inside a sphere? I want to give an epsilon and show that every point in the sphere with radius epsilon has a final limit for both fx and fy.
Have you tried actually writing out the difference quotient for that particular f? Using the fact that xe^{x+ y^2}= xe^xe^{y^2} that should be easy.
f_x = 3^{y^2} \lim_{t\to 0} \frac{(x+t)3^x3^t - x3^x}{t}. This is all kid's play, but how does this help me in determining whether fx is defined for every point in the epsilon-sphere?
If the limit exists for any x (that is to say, that any fx is defined in its domain), would it be enough to show that all of the (x,y) in my epsilon sphere (a circle actually) belong to the domain of the function?
Since f is an elementary function that is defined in all of \mathbb{R}^2. Therefore any point in the epsilon circle (I keep calling it sphere :/ ) would fit the bill no problem. Would this explanation be sufficient?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
