Propagator for quantum linear potential
Peeter
Attempting a problem related to a quantum particle in free fall due to constant force (old exam question)
\begin{align*}H = \frac{1}{{2m}} P^2 + m g X\end{align*}
The last part of the question asks to verify that the position space propagator has the following form
\begin{align*}\phi(x,t) &= \int_{-\infty}^\infty \phi(x', 0) G(x,x';t) dx' \\ G(x,x';t) &=\sqrt{\frac{m}{2 \pi \hbar i t}} \exp\left(\frac{im}{2 h t}\left( x - x' + gt^2/2\right)^2\right)\exp\left(-\frac{img}{h}\left( x t + gt^3/6\right)\right)\end{align*}
(working in the momentum representation to get that far).
One is able to show
\begin{align*}i \hbar \frac{\partial {}}{\partial {t}}\tilde{\phi}(p,t)= (mg) i \hbar \frac{\partial {}}{\partial {p}}\tilde{\phi}(p,t)+ \frac{p^2}{2m}\frac{\partial {}}{\partial {p}}\tilde{\phi}(p,t)\end{align*}
I find as a solution, using separation of variables
\begin{align*}\tilde{\phi}(p,t) = C \exp \left( \frac{1}{{m g i \hbar}} \left( E p - \frac{p^3}{6m}\right) - \frac{i E t}{\hbar} \right)\end{align*}
and verify that this has the form
\begin{align*}\tilde{\phi}(p,t) &= f( p + mg t ) \exp \left( - i \frac{ p^3} {6 m^2 \hbar g}\right) \\ f( p ) &=\tilde{\phi}(p,0) \exp \left( - i \frac{ p^3} {6 m^2 \hbar g}\right) \end{align*}
Relating the position and momentum representation with Fourier transforms
\begin{align*}\tilde{\phi}(p,t) &= \tilde{\phi}(p + m g t,0) \exp \left( - i \frac{ p^3 + (p + m g t)^3} {6 m^2 \hbar g}\right) \\ \phi(x,t) &= \frac{1}{{2 \pi \hbar}} \int dp\tilde{\phi}(p,t) e^{i p x/\hbar} \\ \tilde{\phi}(p + m g t,0) &=\frac{1}{{2 \pi \hbar}} \int dx'\phi(x', 0) e^{-i x'(p + mg t)/\hbar }\end{align*}
Putting these all together and making some changes of variables I can reduce this to the propagator form:
\begin{align*}G(x,x'; t) = \frac{1}{{2 \pi}} e^{-i x' mg t/\hbar} \int dk \exp\left( i k (x-x') -\frac{i \hbar^2 }{6 m^2 g}\left( (k+ mgt/\hbar)^3 + k^3 \right)\right)\end{align*}
But appear out of luck for any easy way to integrate this, so I suspect that I've messed this up in some fundamental way, and am looking to be pointed onto the right path.
With the help of the Airy function
\begin{align*}Ai(x) = \frac{1}{{2\pi}} \int_{-\infty}^\infty e^{i(u^3/3 + ux)} du\end{align*}
and it's Fourier transform
\begin{align*}F(Ai(x)) = \frac{1}{{2\pi}} e^{i k^3/3}\end{align*}
I was able to compute
\begin{align*}G(x,x'; t) = \frac{1}{{2 \pi}} \frac{6 m^2 g}{\hbar^2} e^{-i x' mg t/\hbar} \int_{-\infty}^\infty du \exp\left( i \left( u^3/3 + (x-x') u \right)\right) du\end{align*}
(although I think I may have lost some factors of 3 along the way). This has some similarities to the expected form, but is not a match. We also haven't covered Airy functions in class, so I think there must be some simpler approach.
I'm wondering now if I've improperly assumed that \tilde{\phi}(p,t) is related to \phi(x,t) via Fourier transformation. Perhaps that only makes sense for the free particle case where \left\langle{{x}} \vert {{p}}\right\rangle \propto e^{i p x/\hbar}?
I haven't gone over your calculations, so I can't tell you where your error is, but I can suggest an easier way to do things... In order to verify a solution, all you really need to do is show that the solution satisfies the Time-Dependant Schrodinger's Equation... so why not just show that
i\hbar\frac{\partial}{\partial t} \phi(x,t) = H\phi(x,t)
by calculating the appropriate derivatives?
I was loose in my description of the problem, which asked to show that this is the value for G, and not just verify that it works. I suppose the verification you suggest would do that indirectly, but I think they really did want a derivation.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
