Comparing the Properties of CsF and NaF: Melting Point and Solubility
  • Thread starter Thread starter m0286
    Properties
The discussion centers on comparing the properties of sodium fluoride (NaF) and cesium fluoride (CsF), focusing on their solubility and melting points. NaF has a solubility of 0.042 kg/kg H2O and a melting point of 988°C, while CsF has a significantly higher solubility of 3.67 kg/kg H2O and a lower melting point of 682°C. The conversation highlights that the smaller ionic radius of NaF contributes to its higher melting point, as smaller ions are packed more closely, requiring more energy to separate them. In contrast, the weaker bonds in CsF, indicated by its lower melting point and higher solubility, suggest that the bond length in NaF is longer than in CsF. The discussion also touches on the importance of crystallization systems in understanding solubility differences.
m0286
Hello, I am doing a grade 12 chemistry course, through independent learning and I am stuck on a question... its probably simple and my mind just doesn't want to work.. so hopefully someone could help me out.
I am given the info that NaF has a solubility of 0.042 kg/kg H20 at 25 C and a melting point of 988 C.
And that CsF has a solubility of 3.67 kg/kg H20 at 25 C and a melting point of 682 C.
So what would be the difference between the properties of CsF and NaF?
Chemistry news on Phys.org
NaF having a smaller radius could account for its higher boiling point. If an atom has a smaller radius, that means the elements are closer together, so more heat is needed to separate them.
Did u check whether the crystalization system is the same...?As for solubility,it has to do both with the length of the bonding and with the system of crystalization.
Danie.
Because CsF has a lower melting point and higher solubility than NaF, it means that the CsF bond is weaker than the NaF bond. This makes sense since the bond length for NaF is longer than CsF.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
