Properties of foam plastic in Mattress and in general
Foam plastic, commonly used in mattresses, has specific properties that affect heat retention and insulation. Hot foam retains heat more than cold foam, which can lead to discomfort during sleep. The insulation properties of foam can vary, with some types retaining heat more than others, potentially influenced by the mattress cover as well. The discussion highlights a concern about foam's ability to insulate too much, leading to overheating. Recommendations for mattress types that balance comfort and temperature regulation are also sought.
MQTUAE
Hello,
I wanted to know which properties a foam plastic have in general and how it works in a Mattress.
I have a Foam mattress is there any difference between hot and cold foam?
My Mattress is a Foam mattress not a Spring mattress and it feels too hot after a while you lie on it.
Is it because of the Foam it gets heated and doesn't give away the heat?
So can it be that the Foam insulate too much? or do a Foam not insulate and its only the cover of the mattress?
Thats why i wanted to know the properties of a Foam and of the Foam which is filled in a Mattress or in General.
Does Foam insulate and how it is build or works.
Can you also give me a advice which mattress should i buy which are the best in tests and experience ?
Thanks!
Andy Resnick said:
Are you referring to something like this:
http://www.tempurpedic.com/TEMPUR-Collection/TEMPUR-Collection.asp
http://en.wikipedia.org/wiki/Memory_foam
hi,
this is all about memory foam I am talkin about normal foam made of the same material as like plastic ...i wanted to know about the insulation of foam and heat conduction properties for example.
anyway thanks for your answer.
I'm not a student or graduate in Astrophysics.. Wish i were though... I was playing with distances between planets... I found that Mars, Ceres, Jupiter and Saturn have somthing in common... They are in a kind of ratio with another.. They all got a difference about 1,84 to 1,88x the distance from the previous planet, sub-planet. On average 1,845x. I thought this can be coincidential. So i took the big moons of Jupiter and Saturn to do the same thing jupiter; Io, Europa and Ganymede have a...
  • · Replies 19 ·
9K
  • · Replies 25 ·
