Proportionality with more than one variable?
kochibacha
if x is direct, indirect or exponentially propotional to A and as well as B
can we write x=kAB ? if we write the equation seperately, we have x=k1A, x=k2B when combined, x2=(k1k2)1/2 (AB)2 then x=k3(AB)1/2
to see the real complicate example
EX.1 trypsinogen is converted to trypsin in the body where trypsin itself catalyzes its own reaction
let f(t) = amount of trypsin at time t
let F(t) = amount of trypsinogen at time t
write differential equation satisfied by f(t)
in short, f(t) is direct proportional to product itself f(t) and the substrate F(t)
should i write f'(t)=k f(t)F(t) , =k ( f(t)+F(t) ) , = k (f(t)F(t))1/2 or something else?
Mathematics news on Phys.org
If x is directly proportional to A then there is a constant k such that x = kA.
If x is inversely proportional to A then there is a constant k such that x = k/A.
I have never encountered the terms "indirect proportionality" or a "exponential proportionality". Fortunately, those terms are irrelevant to the questions below.
Yes, we can write x = kAB.
[Editted to eliminate my first erroneous explanation]
It is tempting to multiply the two equations together to get x2 = k1k2AB
The problem is that the x=k1A is true only as long as one holds B constant. The value of k1 includes that constant value of B. Similarly, x=k2B is true only as long as one holds A constant. The value of k2 includes that constant value of A.
It is the reaction rate that is proportional to the product of f(t) and F(t). So rather than f(t) being proportional to itself (a trivial tautology), it is f'(t) that is proportional to f(t).
So the short form would be "f'(t) is directly proportional to the product of f(t) and F(t)"
Likes Terrell
sorry for ambiguous writing it must be X=K(AB)1/2 and f'(t) is direct proportional to product itself f(t) and the substrate F(t)
However, your answer still hasn't answered my questions.
if x is directly proportional to A and as well as B. How can we express x in terms of equations?
if you answered x=constant*A*B could you explain why not x=constant*(A+B)
and what about x=constant1*A , x=constant2*B
when combined, x2=constant1+2*AB
x=+K(AB)1/2 and x=-K(AB)1/2 but we ignore the minus one so x=K(AB)1/2
Suppose for a moment that the above formula held: x = k(A+B) for some constant k.
But we also know that x=k'A for some constant k'.
Take A=1, B=2. Then x=3k by the one equation and x=k' by the second. So k'=3k.
Take A=2, B=1. Then x=3k by the one equation and x=2k' by the second. So 2k'=3k.
Clearly, the only way this can hold is if both k and k' are equal to zero. So x=constant*(A+B) cannot be right except in the degenerate case where x is always zero.
As I wrote, because that constant1 is not a constant. It is a function of B. Similarly, constant2 is not a constant. It is function of A.
What function of A can work for constant1? constant1 = k1B can work.
What function of B can work for constant2? constant2 = k2A can work.
What do you get when you multiply the two equations together now?
Likes 1 person
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
I'm interested to know whether the equation $$1 = 2 - \frac{1}{2 - \frac{1}{2 - \cdots}}$$ is true or not. It can be shown easily that if the continued fraction converges, it cannot converge to anything else than 1. It seems that if the continued fraction converges, the convergence is very slow. The apparent slowness of the convergence makes it difficult to estimate the presence of true convergence numerically. At the moment I don't know whether this converges or not.
