Protecting steel sections from high temperatures
  • Thread starter Thread starter morkeldupreez
    Steel
The discussion revolves around methods to protect steel structures from high temperatures ranging from 650 to 800 degrees Celsius. Participants explore the potential use of ceramic materials for coating steel sections and consider various factors affecting heat transfer and structural integrity in specific applications, particularly in mobile trailers used for transporting solidified materials.
  • Experimental/applied
  • One participant questions whether ceramic materials can be used to coat steel sections and expresses concern that ceramics might retain heat and weaken the steel.
  • Another participant emphasizes the importance of the application context, suggesting that an insulating ceramic with low thermal conductivity could maintain a high temperature differential, allowing steel to conduct heat away or transfer it to surrounding air.
  • Concerns are raised about the heat load and the potential need for an air or water cooling system between the ceramic and steel if the heat flux is high.
  • A participant shares a specific scenario involving a mobile trailer used in a mining context, where steel beams fail due to direct exposure to high-temperature solidified materials.
  • Suggestions are made regarding the design of the trailer, including the possibility of using double-skinned flooring to allow airflow or employing sacrificial tubing to protect the beams.
  • Another participant speculates that refractory linings may not be used due to their fragility during the dumping process and suggests that the beam supports may be under-designed.
  • There is acknowledgment that the hot material cools during transport, which could influence the heat management strategy.
Participants generally agree on the need for more details regarding the application and the heat conditions, but multiple competing views remain regarding the best protective measures and the design considerations for the trailer.
Participants note the uncertainty surrounding heat flux and the specific conditions of the application, which may affect the effectiveness of proposed solutions.
morkeldupreez
Hi there
How can steel structures be protected from 650 to 800 degree celsius temperatures? Can ceramic material be used to coat the steel sections? Will the ceramic material not keep the heat in and weaken the steel?
Any help will be much appreciated
morkeldupreez said:
Hi there
What is the application of the steel - building structure or furnace housing? The application is key.
An insulating ceramic will have a low thermal conductivity (insulator) and therefore low heat transfer, which will maintain a high temperature differential across the ceramic. With the heat flux (transfer rate) sufficiently low, with steel can conduct away the heat or the heat is convectively transferred to the surrounding air.
If the heat load is high, then an air or water cooling system could be installed between the ceramic and steel.
You really need to give more details of the application (This is not a homework question I hope)
As Astronuc has indicated it depends upon time and heat flux.
Its something I've seen at a mine a while back and it got me thinking.
Its a structure (a mobile trailer) that they put solidified material on that is around the temperature specified earlier.
They usually dump the material directly onto the steel structure, but due to the heat, the steel beams fail quite regularly.
I thought ceramic material could be a solution but wasn't sure, because I do not know that much about it.
The heat flux and stuf like that is unknown.
I know they use the trailer to transport the material about 1000m.
Unknown exactly, but can be estimated sufficiently for our purposes.
From your description, the material placed on the trailer is cooling anyway and does not have a continuous new supply of heat.
I would hazard a guess that refractory linings for the trailer are not used because they are too fragile to survice the dumping process and the jolting from the journey.
I further guess that the beam supports for the trailer are under-designed if they fail often. Simply making them of more massive section should take care of this.
As to the trailer bed you haven't indicated if the hot material is placed directly onto the beams or onto some sort of sheet flooring.
Either way some possibilities suggest themselves.
Firstly any flooring could be double skinned, allowing airflow between the skins. this would prevent excess heat reaching the beam sections.
Alternatively if there is no flooring then flat sacrificial tubing placed (fixed) on top of the beams would serve the same job.
Alternatively the works may simply be in too much of a hurry and allowing the hot material to cool for another couple of minutes may do the trick.
From what I've seen is the current trailer designed in such a way that the hot material is placed directly on top of the steel beams.
They put the hot material on the trailer and it is then transported to an area where it is dumped to be cooled.
The sacrificial tubing is something I did not think of.
Thanks guys
  • · Replies 21 ·
10K
  • · Replies 17 ·
