Protein Measuring: Standard vs Sample Solutions
  • Thread starter Thread starter mountain
    Measuring Protein
In the discussion, the preparation of standard and sample solutions for protein concentration measurement is outlined. Standard solutions consist of 800 µL water, 20 µL of each standard solution, and 200 µL of dye concentrate, while sample solutions include 800 µL water, 4 µL of each sample solution, and 200 µL of dye concentrate. A key question arises regarding the interpretation of a measured concentration of 0.5 mg/mL for a sample. It is clarified that this value reflects the concentration based on the 4 µL sample volume, and adjustments should be made to express the concentration consistently, typically per mL. The discussion emphasizes that the standards serve as a reference for quantifying the samples, and all calculations should align to a common scale to ensure accuracy in reporting protein concentrations.
mountain
When I make the standard curve then each standard solution is prepared like this:
800ul water
20ul each standard solution
200ul dye concentrate
The samples are prepared like this:
800ul water
4ul each sample solution
I wonder if I for instance get 0.5mg/ml on one of my sample. Does this mean that this value is the concentration of the original sample or should I multiply with 5 since the volume of the standard is larger (20ul) then the volume of the sample (4ul)?
Biology news on Phys.org
Could you be more specific of how you are measuring your proteins?
Are you using a spec?
Usually the standards just standardize your samples, a ladder to measure against.
The only thing you should be compensating for is the volume you put in. You are measuring the concentration /4ul. This then should be calculated so you have a value either per ul or per ml. Its hard for me to say exactly because I'm not sure how you are measuring the protein concentration. Usually the standards tell you the amount of protein you are adding and everything should be calculated to be on the same scale (eg how many ug/ml and not ug/5ml for one and ug/3ml for another sample).
Thread 'Did they discover another descendant of homo erectus?'
The study provides critical new insights into the African Humid Period, a time between 14,500 and 5,000 years ago when the Sahara desert was a green savanna, rich in water bodies that facilitated human habitation and the spread of pastoralism. Later aridification turned this region into the world's largest desert. Due to the extreme aridity of the region today, DNA preservation is poor, making this pioneering ancient DNA study all the more significant. Genomic analyses reveal that the...
Popular article referring to the BA.2 variant: Popular article: (many words, little data) https://www.cnn.com/2022/02/17/health/ba-2-covid-severity/index.html Preprint article referring to the BA.2 variant: Preprint article: (At 52 pages, too many words!) https://www.biorxiv.org/content/10.1101/2022.02.14.480335v1.full.pdf [edited 1hr. after posting: Added preprint Abstract] Cheers, Tom
https://www.nhs.uk/mental-health/conditions/body-dysmorphia/ Most people have some mild apprehension about their body, such as one thinks their nose is too big, hair too straight or curvy. At the extreme, cases such as this, are difficult to completely understand. https://www.msn.com/en-ca/health/other/why-would-someone-want-to-amputate-healthy-limbs/ar-AA1MrQK7?ocid=msedgntp&cvid=68ce4014b1fe4953b0b4bd22ef471ab9&ei=78 they feel like they're an amputee in the body of a regular person "For...
