Proton electric potential/ final speed calculation
physicsstar26
A proton (q=+e, m= 1.67*10^-27 kg) traveling at 300 m/s enters a uniform electric region opposite to the field direction.
a.) find the change in the energy of the proton as it moves 2 m across a potential difference of 100kV in this field. Express answer in eV.
b) find the final speed of the proton in km/s
a) W=q*V
V= k*q/r I'm confused as to how to approach this problem.
b) once you know V or the above answer do you just plug it into V= (1/2) mv^2/q?
thanks
physicsstar26 said:
a) W=q*V
thanks
What does your equation (a) represent? How will it relate to the change in (what?) energy of the proton?
As for the next equation, since the proton is in a *uniform* field, will that equation be useful? What does *it* represent?
for (a) would you just use Va-Vb= E* dl to find the potential difference?
Well, you can take that route to work out the force on and acceleration of the proton. That will let you answer (b), after which you can back-figure part (a).
Alternatively, you can use the potential difference to figure out the kinetic energy change of the proton, then work out part (b). Either approach requires about the same amount of calculation.
Ah, be careful in handling either the kinematics or energetics for this situation. What is the proton going to do in this field?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
