Proton in magnetic and electric field
To ensure a proton moves un-deflected in a combined magnetic and electric field, the electric field must be oriented in the -y direction. The magnetic field, directed in the -z direction, exerts a force on the proton moving in the +x direction, which necessitates an opposing electric field to balance the forces. The relationship between the electric and magnetic forces is described by the equation qE = qVB. The discussion highlights the application of the right-hand rule (RHR) to determine the direction of forces acting on the proton. The consensus confirms that the correct orientation for the electric field is indeed -y.
syhpui2
As shown in the figure below, a proton moves in the +x direction with speed v and is immersed in both, a uniform magnetic field, B, oriented in the -z direction, and a uniform electric field, E (not shown in the diagram). What electric field orientation is required in order for the proton to move un-deflected through the combined magnetic and electric field region?
(a) +y direction
(b) -y direction
(c) +z direction
Answer is B.
http://i.imgur.com/1G80T.png
qE=qVB
I used RHR, I get answer A...
Which way does the B field push on the proton?
Which way should the E field push on it?
Which way does the B field push on the proton? Along x-axis
Which way should the E field push on it? Opposite direction of qvb?
