Calculate Velocity of Protons in CM Frame After Elastic Collision
  • Thread starter Thread starter latentcorpse
    Proton Scattering
latentcorpse
proton mass 938MeV/c^2. Consider an elastic collision between two protons. IN the centre of mass frame the kinetic energy of each proton is equal to its rest energy.
calculate the speed of the protons in the CM frame.
clearly they will be equal and opposite velocities so the two speeds should be the same.
E=mc^2
then equate that to relativistic energy momentum relationship E=\sqrt{c^2p^2+m^2c^4} but then i get p=0 so I am going wrong somewhere...
I assume you set E = the rest energy leading to p = 0. But it says the kinetic energy is equal to the rest energy, there's also it's rest energy!
(Kinetic energy + Rest energy) = sqrt(p^2 + m^2)
do you mean i should have c^2p^2=m^2c^4
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
