Prove Equation: Algebraic Problem I Need Help With
  • Thread starter Thread starter danja347
The discussion centers on proving the equation \tilde{(\hat{A} + \hat{B})^*} = \tilde{\hat{A}}^* + \tilde{\hat{B}}^*, which involves understanding the meanings of the symbols used, such as tildes, stars, and hats, likely representing complex conjugates and transposes. Participants agree that the operations are linear, but caution that linear operators can be bounded or unbounded, complicating the proof. A more general formula for bounded linear operators is mentioned, indicating the need for careful consideration in proving the equality. The original poster seeks specific advice on how to demonstrate this equality rather than simply stating the linearity of the operators. Overall, the discussion emphasizes the complexity of the problem and the need for a detailed approach to the proof.
danja347
I need help proving this equation... Thankful for all answers!
<br /> \tilde{(\hat{A} + <br /> \hat{B})^*} = <br /> \tilde{\hat{A}}^* + <br /> \tilde{\hat{B}}^*<br />
I hope you can read my nice Latex equation! :)
Explain what everything means:tilda stands for what?star stands for what?hats stand for what??
P.S.I had my glasses on,so i could read it. :wink:
I would assume it is about (complex) conjugates and transposes, but I'm not sure..
at think the same thing arildno...and since these operations are per definition linear there is not much to say...
regards
marlon
regards
marlon
The problem is not that simple.In general,linear operators can be bounded/unbounded.So the general formula reads.
(\hat{A} +\hat{B})^{+} \supseteq \hat{A}^{+}+\hat{B}^{+}
,where the sign for operator equality stands for bounded linear operators A and B.
My latex knowledge ís not that good... but dextercioby wrote my problem down for me except that there is an equality sign in my problem! What i want to do is to prove equality. I can't just say that the operators are linear and write the answer down.
Please... some advice!
