Prove Hausdorff's Maximality Principle by the W.O.P.
Terrell
Show Hausdorff's Maximality Principle is true by the Well-Ordering Principle.
2. Relevant propositions/axioms
Case 1: ##\forall x,y\in X## neither ##x\prec y## or ##y\prec x## is true. Hence any singleton subset of ##X## is a maximal linear order.
Case 2: ##\prec## is a linear order on ##X##, then ##X## is itself the maximal linearly ordered subset of ##X##.
Case 3: ##\prec## is undefined on some pairs ##a,b\in X##. Then ##\prec## is not the relation that well-orders ##X## since there exist subsets of ##X## that does not have a least element.
Question: How can I use the Well-Ordering Principle here? I was thinking of defining a new relation ##\prec_w## that well-orders a finite ##W\subseteq X##, but I'm thinking that that cannot be right since ##\prec_w## is not an arbitrary partial-order relation in ##X##. Which part of this problem should I think more about in order to help me proceed? Or May I simply say that we remove all elements in ##X## that has an undefined relation with all other elements in ##X##?
EDIT: (Alternative case 3: W.O.P.##\rightarrow## A.C. ##\rightarrow## H.M.P.)
Suppose ##\{X_{\lambda}\}_{\lambda\in\Lambda}\neq\emptyset## and ##\forall\lambda\in\Lambda, X_{\lambda}\neq\emptyset##. We want to show ##\prod_{\lambda\in\Lambda}X_{\lambda}\neq\emptyset##. By the well-ordering principle, ##\exists\prec_{x}\forall\lambda\in\Lambda##, ##X_\lambda## is well-ordered; that is with respect to ##\prec_x##, ##\forall\lambda\in\Lambda\forall W\subseteq X_{\lambda}##, ##W## has a least element. Hence, we can simply define a choice-function ##f: \{X_\lambda\}_{\lambda\in\Lambda}\rightarrow\bigcup_{\lambda\in\Lambda}X_\lambda## such that ##f(X_{\lambda})=x_{0}^{\lambda}## denote the least element in ##X_{\lambda}##. Therefore, ##\prod_{\lambda\in\Lambda}X_{\lambda}\neq\emptyset##.
Finally, we want to show A.C. ##\rightarrow## H.M.P. Suppose ##\prec## does not well-order ##X##, then ##\exists a,b\in X## where neither ##a\prec b## or ##b\prec a## are true. Consider some partition of ##X## denoted ##P[X]##. Define ##\hat{X}:=\{\hat{x}\in X:\forall\overline{X}\in P[X]\forall x\in\overline{X},\neg (\hat{x}\prec x\quad\lor\quad x\prec\hat{x})\}##. By the axiom of choice, ##\hat{X}\neq\emptyset##. Thus, ##X^*=X\setminus\hat{X}## is linearly ordered such that ##\forall x\in\hat{X}, X^*\cup\{x\}## is no longer linearly ordered. Therefore, ##X^*\subseteq X## is a maximal linearly ordered subset of ##X##.
So I think I have two questions. First, is how to proceed directly from W.O.P. to H.M.P. and second, is I would like a verification on my alternative case 3 (i.e. did I use W.O.P. and A.C. correctly?)
I can't follow your reasoning in the last paragraph. It does not seem to me that AC implies that ##\hat X\neq \emptyset##. Consider the case X={a,b,c,d} with the only order relations being a>b and c>d. Then X is not well-ordered because the subset {b,c} has no first element. Also, neither b<c nor c<b is true. But every element of X is in one order relation, so no element can be in ##\hat X##, hence ##\hat X=\emptyset##.
Also, is the principle of transfinite induction or the principle of transfinite recursive definition in your toolkit? They can sometimes be useful in making proofs of things like this.
Likes Terrell
I'll consider using this when I get my mind back to this problem. Thanks for the hint! :)
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
