Prove [itex]\lim_{a\to 0}\frac{1}{a} = \infty[/itex]
  • Thread starter Thread starter operationsres
operationsres
Prove \lim_{a\to 0^+}\frac{1}{a} = +\infty under the \epsilon[/math] definition of a limit.<br /> <br /> <b>2. The attempt at a solution</b><br /> <br /> Well, I can&#039;t do \frac{1}{a} - \infty &amp;lt; \epsilon can I? Otherwise it&#039;s just obvious that it&#039;s infinity ..
For this particular problem you need to alter your definition abit since |f(x) - ∞| < ε translates into a useless statement.
You want to use this definition :
\forall M&gt;0, \exists δ&gt;0 \space | \space 0&lt;|x-c|&lt;δ \Rightarrow f(x) &gt; M
What this definition essentially means is that we can find a delta such that the function grows without bound.
Start by massaging the expression f(x) > M into a suitable form |x-c| < δ which will give you a δ which MIGHT work.
Then take that δ and show that it implies f(x) > M.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
