Prove rms voltage using integration
To prove that the RMS voltage of the AC voltage function v = sin(x) is 0.707V, one must calculate the root-mean-square value, which involves finding the average of the square of the function over a specified interval. The formula for this average is the integral of the square of the function divided by the interval length. By integrating (sin(x))^2 over one complete cycle from 0 to 2π and applying the RMS formula, the result will confirm that the RMS value is indeed 0.707V. This method can be applied to any sinusoidal function to derive its RMS voltage. The integration process is essential for validating the RMS calculation.
iamnew
ac voltage
v=sinx
how do you prove that rms voltage is 0.707v using integration
The root-mean-square value of a function is the root of the average of the square of the function.
The average of the square of a function f (x) over an interval is given by:
\frac{\int_{t_{1}}^{t_{2}} (f (x))^{2} dx}{t_{2} - t_{1}}​
You can do the relevant integration yourself for f (x) = sin x (or any sinusoidal function for that matter)
