Prove this is greater than or equal to 8
  • Thread starter Thread starter Chinnu
Chinnu
Show that, if a, b, c >0 and a+b+c = 1, then,
(\frac{1}{a}-1)(\frac{1}{b}-1)(\frac{1}{c}-1) \geq 8
The usual math is ok
I multiplied them out to get:
(\frac{1}{abc}-\frac{1}{ac}-\frac{1}{bc}+\frac{1}{c}-\frac{1}{ab}+\frac{1}{a}+\frac{1}{b}-1)
= (\frac{1}{abc}-\frac{b}{abc}-\frac{a}{abc}+\frac{ab}{abc}-\frac{c}{abc}+\frac{bc}{abc}+\frac{ac}{abc}-1)
= (\frac{1-b-a+ab-c+bc+ac-abc}{abc})
= (\frac{ab+bc+ac}{abc}) = (\frac{1}{a}+\frac{1}{b}+\frac{1}{c}), ...as 1-(a+b+c) = 0
abc is a small number as a,b,c are all less than 1, and it is and order smaller than
anything in the numerator. OR, since a, b, c < 1,
(\frac{1}{a}+\frac{1}{b}+\frac{1}{c}) > 3
Now I don't know what to do. I'm not even sure I'm on the right track...
There may be some other logic I should be using to make this easier, but I don't see it.
According to what you wrote, a + b + c = 1. You haven't used this fact. If you do, you can get an expression that doesn't involve c.
so, use c = 1 - a - b, substitute that into the first equation, and see what happens?
That's what I had in mind, yes.
I tried that, and was able to factor things a lot, but I wasn't able to show that the expression on the left is >= 8.
Where you might go next is to consider w = f(x, y) = (1/x - 1)(1/y - 1)( (x + y)/(1 -x - y)). Use calculus to show that there is a global minimum, and that the minimum value is 8.
I will try this. Also, would it be possible to see if:
(\frac{1}{a}-1) \geq 2,
as, if this is done, without loss of generality, it would apply to each, and 2x2x2 \geq 8
The inequality above is true for 0 < x <= 1/3.
I can't judge from your title or first post what level of analysis you have had already. So I'll propose a couple of things:
-- the straightforward one if you've had multivariate calculus is to use Lagrange multipliers, since you have a function and a constraint equation in three variables; you will be able to show easily that the critical point occurs where a = b = c ; you would then reduce the function to one with two variables and use the Second Partial Derivative Test to show that the value 8 is a minimum [the Test with three variable is messier]; this is, I believe, essentially what Mark44 is suggesting
-- a non-calculus approach would be to consider that a + b + c = 1 in the first octant is an equilateral triangular region, the portion of the plane bounded by the coordinate planes; the product in question is plainly infinite at the edges of the triangle, so the interior must contain a minimum for the product; the three-fold symmetry of the region suggests that the "special point" lies where a = b = c = 1/3 ; that gives the "right number" for the product, but what is the behavior of the function?; fix one variable and shift one of the others by a small amount, which automatically shifts the remaining variable; show that any deviation from the special point must give a larger product
