Prove using three basic probability axioms
The discussion revolves around proving the inequality P(A ∩ B) ≥ 1 - P(¬A) - P(¬B) for events A and B within a sample space S, using three basic probability axioms. The initial proof attempt rearranges terms and applies axiom 3 to demonstrate that the sum of probabilities leads to a valid conclusion. However, a participant points out that the proof should begin by assuming the opposite of what is to be proven and then deriving a contradiction. This highlights the importance of a structured approach in mathematical proofs, emphasizing the need for logical consistency. The conversation ultimately focuses on refining the proof methodology to align with standard practices in probability theory.
hassman
Prove that P(A \cap B)≥1-P(\bar{A})-P(\bar{B})
for all A, B \subseteq Susing only these axioms:
1) 0 \leq P(A) \leq 1, for any event A \subseteq S
2) P(S) = 1
3) P(A \cup B) = P(A) + P(B) if and only if P(A \cap B) = 0
None.
My proof:
First rearrange the shizzle:
P(\bar{A}) + P(A \cap B) + P(\bar{B}) \geq 1
Now using the fact that the first two terms are disjoint, use axiom 3 to obtain:
P(\bar{A} \cup (A \cap B)) + P(\bar{B}) \geq 1
Next note that the first term is equals to P(S), hence we get:
P(S) + P(\bar{B}) \geq 1
which holds for all B \subseteq S, because P(S) = 1 and P(\bar{B}) \geq 0 for all B.
Is this proof correct?
2) P(S) = 1
None.
My proof:
In proof you can't start out claiming what you are trying to prove - you can only claim it isn't true and arriving at a contradiction. So you would say
Suppose P(A \cap B)<1-P(\bar{A})-P(\bar{B}) then try to arrive at a contradiction.
Got it! Thanks!
