Prove Weak Field Metric Homework Statement
aman02
For the weak field metric
g_{00}=-1+\epsilon h_{00}+O(\epsilon^2)
g_{\alpha\beta}=\delta_{\alpha\beta}+\epsilon h_{\alpha\beta}+O(\epsilon^2)
Prove
R_{00}=-\frac{1}{2}\epsilon\frac{\partial^2h_{00}}{\partial x^\alpha\partial x^\beta}+O(\epsilon^2)
The hint was to use:
R^q_{lmn}=\Gamma^q_{ln,m}-\Gamma^q_{lm,n}+\Gamma^p_{ln}\Gamma^q_{pm}-\Gamma^p_{lm}\Gamma^q_{pn}
R_{ijkl;m}+R_{ijlm;k}+R_{ijmk;l}=0
But I couldn't figure out how, so I included
\Gamma^i_{jk}=\frac{1}{2}g^{il}(g_{jl,k}+g_{lk,j}-g_{kj,l})
R_{jl}=R^i_{jil}
I tried to do it the long way without the Bianchi identity, and started with the basic definition of the Ricci tensor.
R_{00}=R^\alpha_{0 \alpha 0}=\Gamma^\alpha_{00,\alpha}-\Gamma^\alpha_{0 \alpha,0}+\Gamma^p_{00}\Gamma^\alpha_{p \alpha}-\Gamma^p_{0 \alpha}\Gamma^\alpha_{p0}
Then using the definition of the Christoffel symbols,
\Gamma^\alpha_{00}=\frac{1}{2}g^{\alpha \alpha}(g_{0\alpha,0}+g_{\alpha 0,0}-g_{00,\alpha})
g_{\alpha \alpha}\Gamma^\alpha_{00}=\frac{1}{2}(4)(-1+\epsilon h_{00}+O(\epsilon^2))_{, \alpha}
g_{\alpha \alpha}\Gamma^\alpha_{00}=-2\epsilon (\frac{\partial h_{00}}{\partial x^\alpha})+O(\epsilon^2)
Similarly, I found that
g_{\alpha \alpha}\Gamma^0_{0 \alpha}=2\epsilon (\frac{\partial h_{00}}{\partial x^\alpha})+O(\epsilon^2)
It seems from here, the solution is fairly close, but I don't know what to do with the g_{\alpha \alpha}, or if I should even have them. If not, I don't know how to deal with the g^{\alpha \alpha} in the original definition (I just lowered the indices and got the trace of the metric, 4 for our 4-dimensional space-time). Could using Bianchi help? I'm not quite sure how to proceed, any help is appreciated.
that's a bit confusing. You mean that alpha and beta are only 1,2,3 in the second equation?
Prove
R_{jl}=R^i_{jil}
This does not make sense since there are three alphas on the right. be careful with the indices
g_{\alpha \alpha}\Gamma^\alpha_{00}=\frac{1}{2}(4)(-1+\epsilon h_{00}+O(\epsilon^2))_\alpha
This does not make sense. What does 1_\alpha mean? Or what is (h_{00})_\alpha??
I am not sure about the fastest way to proceed but if you do it the long way, why not find g^{\mu \nu } to first order? You should find easily that it is \eta^{\mu \nu} - \epsilon h^{\mu \nu}
Sorry, yes, that is what I meant.
I may have skipped a step - I noticed the only non-zero elements in g_{ab} and g^{ab} are those on the diagonal, so I let l=\alpha. That put a few more alphas in on the right.
Sorry, another typo...that should be (-1+\epsilon h_{00}+O(\epsilon^2))_{ , \alpha}, as in partial derivative of all that with respect to the alpha coordinate. Then 1_\alpha becomes 0, and (h_{00})_\alpha is the partial with respect to alpha.
You're correct, in fact that fact is a different question on the assignment that I did solve, but I wasn't sure what the h^{\mu \nu} would do, because the final solution didn't have anything in it of that form.
Then it is easier to use the notation g_{\alpha \beta} = \eta_{\alpha \beta} + \epsilon h_{\alpha \beta} for all the components or if you give only the spatial part, use latin indices (i,j,k)
why do you assume that g has only diagonal elements?
In any case, even if it was true, you should never write something with three identical indices!
Well, if you rewrite your Christoffel symbols with the correct notation for the indices it will be easier to help with the remaining steps.
Alright, thanks for the help kdv - I've gone through with correct indices and reduced the problem to showing spatial derivatives dominate time derivatives...why would this be true?
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
