Proving Divisibility Property: ab|ac implies b|c
  • Thread starter Thread starter SeanThatOneGuy
The discussion centers on proving the divisibility property that if ab divides ac, then b must divide c, given that a, b, and c are integers with a not equal to zero. The initial confusion arises from the manipulation of the equation ac = ab·k, leading to attempts to simplify and isolate terms. The key realization is that if a(c - kb) = 0 and a is non-zero, then c must equal kb, confirming that b divides c. The participant seeks clarification on their approach and the validity of their steps, particularly after receiving a hint from the professor that caused further confusion. Ultimately, the proof hinges on the correct application of the properties of divisibility.
SeanThatOneGuy
I'm really having trouble with this proof. at first I thought, oh easy the a's cancel then I realized I am proving that property so that was no help at all. Here is my work so far:
--snip--
Let a, b, and c be integers with a≠0.
If ab|ac, we know from the definition of "divides" that there is an integer k, such that ac=ab⋅k
Then (a - c⋅k) = 0 so k(a - b⋅k) = 0
Since we know that a≠0, then b|c.
--snip--
I'm pretty sure that I'm off the rails after "such that ac=ab⋅k" anyone care to help me? please?
Where did that come from?
ac=ab.k => c=b.k
I got a hint from the professor and it really threw me for a loop
--snip--
Then (�� - ��⋅�) = 0 so �(� - �⋅�)
--snip--
so, I was trying to make that form work.
ac-kab=0 therefore a(c-kb)=0. Since a≠0, c-kb=0 or b|c.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
