Proving Increasing Sequence or Showing Convergence of {a_n}
mynameisfunk
Suppose that {a_n} is a bounded sequence of real numbers such that, for all n, a_n \leq \frac{a_{n-1}+a_{n+1}}{2}. Show that b_n=a_{n+1}-a_n is an increasing sequence. Otherwise show that {a_n} converges.
I do not see it at all..
It seems that since 2a_n \leq a_{n-1}+a_{n+1} that the sequence could be either increasing OR decreasing. i could fit the set of integers, either increasing or decreasing and the inequality holds and b_n is stagnate. BUT, since {a_n} is bounded, it must be convergent?? i couldn't find any theorems or anything to support this claim though. Possibly "For a real valued sequence {s_n}, \lim_{n \rightarrow \infty}=s iff it's lim sup=lim inf =s (as n approaches infinity)" ??
Well your claim is not quite correct; that is why you couldn't find a theorem to support it.
There are tons of bounded sequences that are not convergent.
Eg
(-1,1,-1,1...)
I have not tried the problem but I think I see what you mean by the sequence can be either decreasing or increasing.
I see 3 things
1) If the sequence is increasing then it is increasing at an increasing rate and is therefore not bounded.
2) If it is decreasing it is decreasing at a decreasing rate and could possible converge.
3) If it is constant then we know it converges.
I believe your best bet is to show that the sequence is cauchy. For one thing we know the sequence is not increasing. :)
is it possible to take n to -\infty? We have never done that before..
Hey mate.
I made a mistake; b_n is actually increasing by definition. b_n is the distance between sucessive points and if you rearrange the first inequaility it is extremely easy to see that b_n-1 <= b_n which is what we want.
I actually arrived at that result in my original post but I was too stupid to notice that (1) was, in fact, the desired result.
Sometimes extremely obvious things are hard to see :-) :-).
Ya, I was able to arrive at that as well, but I am kind of confused by what I am supposed to do in the 2nd part. a_n shouldn't converge since a_n-a_{n-1} \leq a_{n+1}-a_n, right?? But since a_n is bounded, I suppose the b_n must be bounded above?
The question ask you to either shown b_n is increasing or a_n is convergent. You have showed that b_n is increasing so you are done.
You do not have enough info to say that a_n converges. In fact I don't think it does.
OK, well what about this. Can i deduce from the fact that a_n-a_{n-1} \leq a_{n+1}-a_n and that a_n is bounded and is either monotonically increasing or decreasing and that every monotonically increasing/decreasing sequence converges iff it is bounded?
I don't think so but you should probably get a second opinion.
{a_n} can't converge. It's not Cauchy : ).
EDIT: Well, I guess if they were all negative terms, and b_n was increasing to zero, then maybe.
thanks, very helpful
b_n increases to zero is the key. That gives a_n convergent.
