Proving initial speed of a particle
To prove the initial speed of particle A, the equation v² = v₀² + 2gh is utilized to determine the speed of particle B just before it falls. Given that particle B falls a height of 0.8m, its speed can be calculated using gravitational acceleration. Once B's speed is known, conservation of momentum principles are applied to find the speed at which particle A begins to move. The calculations confirm that particle A's initial speed is 1.04 m/s when B falls. This approach effectively combines kinematic equations with momentum conservation to solve the problem.
paradiselost
Particle A of mass 1kg is at rest 0.2m from the edge of a smooth horizontal table 0.8m high. It is connected by a light inextensible string of length 0.7m to particle B of mass 0.5kg. Particle B is initially at rest at the edge of table closest to A but then falls out. Assuming B's initial horizontal velocity is zero, prove that speed which A begins to move is 1.04m/s
F = ma
Momentums : m(v-u) etc.
I solved it before, but I can't seem to remember how to =(
do you know this equation:
v^{2}=v^{2}_{0}+2gh
which can be derived from equation of motion in straight line with constant acceleration. You can use it to find speed of B at the moment when it starts to pull ball A. When you have this velocity, use conservation of momentum.
