Proving or Disproving a Statement in Set Notation
amilapsn
Prove or disprove the following
(i) ##\forall a\in\mathbb{R}[(\forall \epsilon>0,a<\epsilon)\Leftrightarrow a\leq 0]##
2. The attempt at a solution
Can't we disprove the above statement by telling ##a\leq 0 \nRightarrow (\forall \epsilon>0,a<\epsilon)## through a counter example like ##a\leq 0 \Rightarrow (\epsilon=0,a\leq \epsilon)## or something?
Can you write out in words what the proposition is saying?
What would you have to show to prove it? Hint: there would be two parts to proving it.
Can you write down what property a countereaxmple would have? Hint: it could have one of two properties.
Does it hold for a = 0? Does it hold for a = -1? Does it hold for a = 1?
The proposition in words:
for all a belongs to real number set , for all ##\epsilon## >0 and a<##\epsilon## if and only if ##a\leq 0## .
I have to show both ##\forall \epsilon >0,a<\epsilon\Rightarrow a\leq 0## and ##a\leq 0\Rightarrow \forall \epsilon >0,a<0## to prove the proposition.
A counter example should disprove the proposition.
That's good.
What about a = 0, 1, -1? Does the proposition hold for these values of a?
The proposition holds for a=-1,0. But it doesn't hold for a=1.
Why does it fail for a = 1?
Because a=1 is not less than for all ##\epsilon>0##
Take a step back. We have a proposition:
##\forall a \ \ A \Leftrightarrow B##
That's means that (if the proposition holds) then for each a we have either: A(a) true and B(a) true; or A(a) false and B(a) false.
For a = 1, what can you say about A(1) and B(1)?
Likes amilapsn
I see. The proposition holds for a=1 too, because A(1) false and B(1) false. Thanks...
Thank you for showing me the better way to look at the question.:smile:
Then the proposition is true for all a, so that we can't disprove it. We have to prove it. Thanks again @PeroK
Also, when I first asked you to describe the proposition in words, you could have said:
The proposition states that:
"Any real number is less than or equal to 0 iff it is less than every positive number".
Put like that, it's clear that the proposition holds.
Likes amilapsn
Yeah, it's really clearer...
Here's a tip. This is something I do when dealing with propositions and logic:
I use "true" and "false" to relate to individual statements. E.g. ##a > 0## can be true or false.
And, I say a proposition "holds" or "fails". E.g. the proposition holds for a = 1.
Just now I felt what is called as "Enlightenment..."
