Proving Regularity in Y through Closed Continuous Surjective Maps
  • Thread starter Thread starter guroten
guroten
Let f : X--> Y be a closed continuous surjective map such that f^(-1)(y) is compact.
Show that if X is regular, so is Y .
I'm not sure which piece of info I need to use to start each of these. Any help with the proof would be really appreciated. I already figured out how to show that if X is Hausdorff , so is Y, but I can't figure out how to show it's regular.
Pick a closed set C in Y. You know for every element x of f^(-1)(y) that x and the closed set f^(-1)(C) have nonoverlapping neighborhoods. Next use the most basic property of compact sets. That's a hint to get you started.
Okay, so I can use compactness to find a finite open covering that is disjoint from the other neighborhood. How can I turn these open sets in X into disjoint open sets in Y? Since the mapping is closed, I have tried to use complements to find the proper disjoint sets, but it is not working.
Take the union of the neighborhoods in the finite covering and call it U. Take the intersection of the corresponding neighborhoods of f^(-1)(C) and call it V. Now map those two neighborhoods into Y. What's not working? Oh, I see. So far we only have that f^(-1)(y) and f(-1)(C) are separated in X. Hmmmm.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
