Proving T is Normal from \left\|T^{*}v\right\|\leq\left\|Tv\right\|
  • Thread starter Thread starter Quantumpencil
    Normal
Quantumpencil
Suppose V is an inner product space and T\in L(V). Prove that if \left\|T^{*}v\right\|\leq\left\|Tv\right\| then T is Normal.
Sorry for being bothersome; this is the first year I've ever written proofs so I'm a bit sketchy about them.
Define an Inner Product on V \left\langle Sv, Tv\right\rangle = \ Trace(ST^{*}).
Then \left\|T^{*}v\right\|\leq\left\|Tv\right\| = Trace (TT^{*}) \leq Trace( T^{*}T).
However, \ Trace (TT^{*}) = Trace (T^{*}T). Which implies \left\|T^{*}v\right\| = \left\|Tv\right\|, and therefore T is normal
I worked up another solution, which I'm almost sure is correct, but if this one does indeed check out I'd prefer to use it ;p. It just seems wrong to me for some reason; because it implies that basically all linear maps are normal; but I can't place what I did incorrectly.
That is not an inner product on V, it is an inner product on L(V).
What justification do you have for \left\|T^{*}v\right\|\leq\left\|Tv\right\|?
We assumed that T*v was less than or equal to Tv; in order to show that T had to be normal.
An inner product on L(V), right. I think that destroys my "proof." Since it doesn't make sense to take the "Trace" of a vector.
I have another brief question; If all the eigenvalues of a particular operator are equal to 0, does that imply the operator is equal to 0? or just Nilpotent? The other proof I worked on shows that TT*-T*T is positive, and since Trace of that operator is 0, It must have all zeros along the diagonal. Then I sort of hand-wavily assumed I could say TT*-T*T = 0, and therefore TT* = T*T and T is a normal operator. Is there any solid justification for that?
EDIT: Nevermind I think I figured it out. T is Positive, so it's also self-adjoint; which means V has a basis of eigenvectors, but since all the eigenvalues are 0, TT*-T*T must be the zero map.
Hurray!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
