Proving that the orthogonal subspace is invariant
Dixanadu
Hi guys,
I couldn't fit it all into the title, so here's what I'm trying to do. Basically, I have a unitary representation V. There is a subspace of this, W, which is invariant if I act on it with any map D(g). How do I prove that the orthogonal subspace W^{\bot} is also an invariant subspace of V?
I know that an orthogonal matrix is one where its transpose is its own inverse, but I don't know how to apply that here. Can you guys help me out?
thanks!
There's only one way that you can apply it really - you should start by writing out explicitly what it is you need to prove, and then use the fact that you have a unitary transformation.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
