Proving the limit (delta epsilon)
  • Thread starter Thread starter zeion
    Epsilon Limit
The discussion focuses on proving the limit of the function as x approaches 1 using the epsilon-delta definition. The initial approach involves manipulating the expression to establish bounds, specifically focusing on how to control the term |(2x + 1)/(3(x^2 + x + 4))|. A suggested method includes assuming |x - 1| < 1 to simplify the bounds on x and subsequently derive a relationship between |x - 1| and epsilon. The conclusion emphasizes the need to choose delta as the minimum of 1 and a derived expression based on epsilon to ensure the limit condition is satisfied. The conversation also touches on the appropriateness of selecting values less than the limit point, which is confirmed as a valid strategy.
zeion
Prove the follow statements directly using the formal \epsilon , \delta definition.
\lim_{x\rightarrow 1} \frac{x + 3}{x^2 + x + 4} = \frac{2}{3}
0 &lt; |x - 1| &lt; \delta \rightarrow 0 &lt; |\frac{x + 3}{x^2 + x + 4} - \frac{2}{3}| &lt; \epsilon
Not sure what to do now.
0 < | 3(x+3) - 2(x2 + x + 4) / 3(x2+x+4) | < e
0 < | -2x2 + x + 1 / 3(x2+x+4) | < e
0 < | (-2x - 1)(x - 1) / 3(x2+x+4) | < e
Now I can control (x - 1), but how do I do this?
Should I have posted this in the "Calculus and Beyond" section? :/
Now you need to get a bound on |(2x+1)/3(x^2+ x+ 4)|
For example, you can start by assuming that |x-1|< 1 so that 0< x< 2. Then 0< 2x< 4 and 1< 2x+1< 5. Also 0< x2< 4 so 0< x2+ x< 6, 4< x2+ x+ 4< 10 and 12< 3(x2+ x+ 4)< 30. That tells you that 1/30< 1/3(x2+ x+ 4)< 1/12 and so that 1/30< (2x+1)/3(x2+ x+ 4)< 5/12.
Now you know that |x-1|/30< (2x-1)|x-1|/3(x2+ x+ 4)< 5|x-1|/12
Since you want to make sure that is less than \epsilon, you want 5|x-1|/12&lt;\epsilon so you need |x-1|&lt; 12\epsilon/5. To make certain that |x-1|< 1 so all of that is true, take \delta to be the smaller of 1 and 12\epsilon/5|.
I've been told that I should only pick values that are less than whatever x is approaching (ie. <1 in this case), is this true?
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
