Proving the Limit of a Sequence Math Problem with Continuous Function f(x)
  • Thread starter HACR
    Sequence
6 replies · 2K views · last reply
HACR
Prove that if f(x) is continuous for 0<f(x)<1, then [tex]lim_{n->\infty}\frac{1}{n}[(n+1)(n+2)(n+3)...(2n)]^{\frac{1}{n}}=\frac{4}{e}[/tex].
f(x)=log(1+x)
We know that [tex]lim_{n->\infty}\frac{1}{n}[f(\frac{1}{n})+f(\frac{2}{n})+f(\frac{3}{n})+...f(\frac{n}{n})]=\int_0^1 f(x)dx[/tex]
So that [tex]\int_0^1 log(1+x)(=f(x))dx[/tex] equals the sequence in the limit.
But evaluation of the integral shows that it is a divergent one.
There's no way that integral can be divergent. In the interval between 0 and 1, log(1+x) is bounded by 0 and log(2), respectively. So the integral of log(1+x) needs to be between 0 and log(2). It should be relatively easy to prove that the integral is bounded above and below by those two numbers.
Right, I should've fixed the limits of integration from 0to 1 to 1 to 2 when i did it. Thanks for point it out. Although I think the 1/n power indicated in the problem is not necessary.
So after you've found the value of the integral, what's your next step? Do you know?
It turned out to be [tex]\lim_{n->\infty}\frac{1}{n}(n+1)(n+2)(n+3)...(2n)=\frac{e}{4}[/tex]
Hmm, but did you remember the 1/n power? First thing I'd try doing is taking the logarithm of the left and right sides.
