Proving Trig Identities: Is this Question Referring to the Pythagorean Identity?
The discussion revolves around proving the trigonometric identity sec θ (sec θ - cos θ) = tan^2 θ. Participants clarify the use of fundamental trigonometric identities, such as sec θ = 1/cos θ and the Pythagorean identity 1 + tan^2 θ = sec^2 θ. The solution approach involves manipulating the left side of the equation to simplify it and verify the identity. There is a consensus that understanding these identities is crucial for solving such problems. The conversation concludes with confirmation that the problem does indeed relate to the Pythagorean identity.
priscilla98
Prove Trig. Identities
1. sec θ (sec θ - cos θ)= tan^2 θ
sec θ = 1/cos θ
tan θ = sin θ/ cos θ
cot θ = cos θ / sin θ
1. sec θ * sec θ - sec θ * cos θ
1/ cos θ * 1/ cos θ - 1/ cos θ * cos θ
----> cos θ is crosses out by the right but I am confused on 1/cos θ. I know 1/cos θ = sec θ. Wait does this problem refer to the pythagorean identity which is 1 + tan^2 θ = sec^2 θ
sec θ = 1/cos θ
Use = !
Generally you want to start on one side and end up with the expression on the other side.
sec θ * sec θ - sec θ * cos θ = sec2θ - 1 = ?
In answer to your question, yes.
Thanks a lot :)
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
