Proving Vector Orthogonality in R^3
The discussion revolves around proving vector orthogonality in R^3, specifically focusing on two problems involving unit vectors and their orthogonal counterparts. The first problem requires demonstrating a relationship involving the cross product of a unit vector and an orthogonal vector, while the second problem involves a more complex expression with multiple cross products of orthogonal unit vectors.
  • Participants discuss the application of the triple product and suggest geometric interpretations of the relationships between the vectors. Some express confusion about how to initiate the proof, while others propose simplifying the problem by choosing specific coordinate systems for clarity.
The discussion is active, with participants offering various approaches and insights. Some guidance has been provided regarding the use of geometric reasoning and the triple product, but there is no explicit consensus on a single method or solution path yet.
Participants note the independence of the equations from the choice of axes, suggesting that specific coordinate choices could simplify the proofs. There is also mention of assumptions regarding the properties of unit vectors and orthogonality that are under discussion.
mjstyle
a) Let v be a unit vector in R^3 and u be a vector which is orthogonal to v. Show v x (v x u) = -u
b) Let v and u be orthogonal unit vectors in R^3. Show u x (v x (v x (v x u))) = -v
I am very lost in this question, I know a unit vector is = 1 therefore the summuation of the vector v is 1 for example, v = (1,0,0). square root(1^2 + 0 + 0) = 1 and i know u dot v is 0 but how do i start the prove?
thank you
Apply the http://en.wikipedia.org/wiki/Triple_product" for the first one then simplify. Do it repeatedly for the second.
That's one way to do it - the other is to think about the geometry. You know that u and v are orthogonal, so that u,v, vxu are all orthogonal, hence you know that vx(vxu) is parallel to u (since it is orthogonal to both v and vxu). What about its length? Again, just think about the geometric meaning. You should be able to show that vx(vxu) has length 1. Now you just need to consider if that means it is u or -u.
Since those equations are independent of choice of axes, it would be perfectly valid to choose you coordinate system so that u is pointing along the x-axis and v along the y-axis.
That is, assume that u= <a, 0, 0> and v= <0, b, 0> in the first problem and u= <1, 0, 0>, v= <0, 1, 0> in the other. Now use
[tex]\vec{u}\times\vec{v}= \left|\begin{array}{ccc}\vec{i} & \vec{j} & \vec{k} \\ a & 0 & 0 \\0 & b & 0\end{array}\right|[/tex]
  • · Replies 24 ·
