Pt. Mass and Spring rotating on table
The discussion revolves around a mass-spring system where a 3 kg mass is attached to a spring with a spring constant of 14 N/m. Key calculations include determining the angular momentum, total energy, and distances related to the mass's motion, with initial results showing angular momentum as 3 kg m²/s and total energy as 7.75 J. The minimum distance from the center of the ellipse is established at 0.5 m, while the maximum distance is found to be 0.93 m. The user expresses difficulty in understanding the proper method for solving these problems, particularly in applying conservation laws effectively. Ultimately, the discussion highlights the importance of conservation of angular momentum and energy in solving mass-spring dynamics.
d843
A mass of m = 3 kg is tied to a point by a massless spring with spring constant k = 14 N/m. Assume the spring has an unstretched length of zero. The mass is pulled a distance of d0 = 0.5 m from the center and given a speed of v0 = 2 m/s perpendicular to the spring. (The mass slides on a frictionless table.)
My Diagram (best I can do with ASCII)
Axis-(SPRING)-(MASS)
X-/\/\/\/\/\/\/-[3kg]
a) What is the angular momentum of the system about the fixed end of the spring?
b) What is the total energy of the system? (Assume the potential energy in the spring is zero when the spring is unstretched)
c) Find the minimum distance of the mass from the center of the ellipse.
d) Find the maximum distance of the mass from the center.
e) Find the minimum speed of the object.
I've solved for a-c (3 kg m2/s, 7.75 J, 0.5 m)
I'm really stuck on d. I know that once I find the answer to d I can solve e pretty quickly (I think the minimum speed will be at the maximum distance-so I can use L=3=Iw^2 and then w=v/r to solve for the velocity)
The hint it gave was "Set up equations for the conservation of angular momentum and energy."
It's entirely possible that I just need to do something else and look at this again later and I'll figure it out, but any help would be greatly appreciated.
Ok,
Well somehow I figured it out. d) 0.93m
Though it was by complete chance that I got the right answer. I was taking my conservation of momentum equation and was playing w/ the potential energy in the spring in the KE conservation eqn. So, it's not so big of a deal now, but if someone could explain the proper way of doing this problem it would be great. Thanks!
