What Is the Speed of the Blocks When They Are at the Same Height?
The discussion centers on a physics problem involving two blocks connected by frictionless pulleys, where one block is heavier than the other. When the weight is removed, the blocks move until they reach the same height, and the potential energy of both blocks converts into kinetic energy. The user correctly deduces that the speed of both blocks is equal at this point and calculates the height where they meet. They conclude that the distance z, where both blocks are at the same height, is 2.5 meters. The solution is confirmed as correct, and the user expresses satisfaction with their understanding.
DrWillVKN
A system has two blocks connected by frictionless pulleys. One block (m = 3kg) is above the other (m = 2kg) vertically, as the other is lowered by a weight. Initially, they are 5m apart, vertically. When the weight is removed, what is the speed of the blocks when they are at the same height?
Wext = dEmech + Wnc
Emech = U + K
U = mgh
K = 1/2 * mv^2
No external forces are done on the system, and no nonconservative forces are done either. Thus, Uf + Kf = Ui + Kf. Kf = 0, and Ui = mgh for both blocks. If the height is 0 when the blocks are the same height, then the Ui of the heavier block (on top) is 3 * g * z, where z is the distance between its initial height and the height where the two blocks meet. This makes the Ui of the lighter block 2 * g * (z-5), giving it negative potential energy. When the weight on the second block is removed, the lighter block will go up, and the heavier will go down. The U of both blocks is converted into kinetic energy.
I assumed that the initial energy was
3 * g * z + 2 * g * (z-5)
and the final was
K = 1/2 * mv^2
Both blocks have the same speed, so m = 3 + 2. This would describe the speed of the system at all points after U is converted completely into K. Does this happen when they are at the same height?
If this is the case, how would I find z?
yeah, your equations are correct:
The length of string is constant. Use this to obtain z.
Do you know that the speed is equal or you "assumed" it??
I assumed it, because it only asks for 1 speed.
So, since they both go up to become 'equal', would z be equal to 5 - z, making z = 2.5 ?
EDIT: alright, it's the right answer, thanks!
DrWillVKN said:
I assumed it
Do you want its proof?
