Pulley problem with moment of inertia
The problem involves a 28.5 kg block (m1) on a horizontal surface connected to a 6.10 kg block (m2) via a massless string over a frictionless pulley with a moment of inertia of 0.140 kgm². A force of 231.3 N acts on m1 at an angle of 30.5°, and the goal is to determine the upward acceleration of m2. The initial approach of ignoring the moment of inertia was incorrect, as it is essential to apply both linear and rotational dynamics. Newton's second law for linear motion and the corresponding equations for rotational motion must be utilized to solve for the acceleration. Understanding the relationship between the forces acting on the blocks and the rotational dynamics of the pulley is crucial for finding the solution.
howsockgothap
A 28.5 kg block (m1) is on a horizontal surface, connected to a 6.10 kg block (m2) by a massless string. The frictionless pulley has a s R = 0.087 m and a moment of inertia I=0.140 kgm2. A force F = 231.3 N acts on m1 at an angle theta = 30.5°. There is no friction between m1 and the surface. What is the upward acceleration of m2?
m2 is hanging off a pulley that's attached to the end of the surface as m1 is dragged across the surface by force F
f=ma
I=?
Initially I tried ignoring the moment of inertia and solving with just tensions but obviously that is not possible. My main problem is that (as you can see from part 2) I am not sure what equation I should be using in reference to the pulley's moment of inertia.
f=ma
I=?
You have correctly identified that you need to use Newton's second law for linear accelerations. What you now need to Newton's second low for Rotations - see: http://hyperphysics.phy-astr.gsu.edu/hbase/n2r.html
