Pullin a string to add energy to a wheel
The discussion focuses on calculating the final rotational speed (w_final) of a bicycle wheel when a string is pulled with a force (F) after a distance (L) has been covered. The moment of inertia is given as I = k m r^2, and participants emphasize using Newton's second law for rotation to find angular acceleration and torque. The work done by the force is crucial for determining the change in rotational kinetic energy, which can be expressed as the sum of initial kinetic energy and work done. A method to find w_final involves relating the final kinetic energy to angular speed using the equation KE_final = 1/2 I ω_final^2. The conversation highlights the importance of understanding rotational dynamics and energy principles in solving the problem.
thinktank75
Suppose that after a certain time t_L, the string has been pulled through a distance L. What is the final rotational speed w_final of the wheel?
Express your answer in terms of L, F, I, and w_0
Extra Info:
w_0 = angular velocity
k = dimensionless constant
m = mass
r = radius
Moment of Inertia = Ikmr^2
QUESTION 1
w_final = ?
QUESTION 2
What is the instantaneous power P delivered to the wheel via the force (F) at time t = 0?
P = ?
I have no clue how to approach the question, help would be much appreciated :smile:
Post the problem exactly as given.
Is the string pulled with a constant force? If so, calculate the work done by that force. (Or calculate the angular acceleration using Newton's 2nd law for rotation.)
Sorry:
A bicycle wheel is mounted on a fixed, frictionless axle, with a light string wound around its rim. The wheel has moment of inertia I = k m r^2, where m is its mass, r is its radius, and k is a dimensionless constant between zero and one. The wheel is rotating counterclockwise with angular velocity w_0, when at time t=0 someone starts pulling the string with a force of magnitude F. Assume that the string does not slip on the wheel.
How exactly do I calculate the angular acceleration? If the velocity is constant, isn't accleration = 0? :blushing:
Use Newton's 2nd law for rotation. (Look it up! It relates torque to rotational inertia and angular acceleration.) Even easier would be to calculate the change in rotational KE of the wheel by figuring out the work done on it.
Sure, but the angular velocity is not constant!
Thank you soo much:smile: I'm going to try it out right now! It's making more sense now :smile:
I got:
W_final: FL + (I*W^2 / 2)
P = Fr * w
but they're both wrong, I don't know what's wrong with the responses... please help...
Not sure what those equations are, but try one of these:
Using energy methods: The work done by the force equals the change in rotational KE.
Using forces: The torque produces an angular acceleration.
Using Impulse: The angular impulse equals the change in angular momentum.
my book says:
for the w_final:
i need to find the initial KE of rotation
Iw^2
and I need the work done by the applied force:
w = F*L
then they said to find the final kinetic energy, you add those 2 both together.
now that I have the final KE how to I find the final rotational speed?
thanks
thinktank75 said:
my book says:
for the w_final:
Iw^2
w = F*L
All good. This is exactly what I suggested when I recommended the "energy method".
You know how rotational KE relates to angular speed--you've written that expression twice:
{KE}_{final} = 1/2 I \omega_{final}^2
Just solve for \omega_{final}.
