Pulling block up incline with winch.
A 1200 kg block of granite is being pulled up a 23° incline at a constant speed of 1.23 m/s by a winch, with a kinetic friction coefficient of 0.14. To determine the power required from the winch, the tension in the cable must first be calculated. A force diagram is suggested to analyze the forces acting on the block, including friction and weight. The key is to establish a force balance since the block is moving at constant speed, meaning the pulling force must equal the sum of friction and gravitational components. Understanding these forces will lead to the necessary calculations for power.
bkhofmann
A 1200 kg block of granite is pulled up an incline that has an angle of inclination q = 23 ° with a constant speed of 1.23 m/s by a steam winch (see Figure). The coefficient of kinetic friction between the block and the incline is 0.14. How much power must be supplied by the winch?
(That I know of) P=TxV
I need help finding the tension in the cable between the winch and block. Thanks in advance!
Welcome to PF.
Draw a force diagram. What forces are there? What forces are there along the line of the Tension in the cable that needs to be overcome?
Forces in the X direction are friction and weight (MG) and of course T which we need to find. I', just stuck on how to use these.
OK. Write a force equation. What must be balanced if it is not accelerating, but moving at constant speed?
The force of friction and mg and the pulling force.
