Pump drive torque measurement problem
The discussion centers on measuring the torque of a plunger pump driven by an eccentric cam, with concerns about the influence of heavy couplings on the torque readings. The setup includes a motor, couplings, a torque transducer, and the pump, but the goal is to isolate the pump's torque from that of the couplings. It is noted that the couplings are symmetrical, suggesting their drive torque remains constant throughout the driveshaft's revolution. The user seeks guidance on converting the rotational inertia of the couplings into a resistive torque to accurately subtract from the total torque readings. The clarification provided indicates that if the motor operates at a fixed speed, the couplings will not require additional torque unless there is rotational slack.
daveydude_99
Hi all!
Basically I will soon be required to measure the torque required to drive a plunger pump which operates by an eccentric cam on the pump's driveshaft pushing a plunger up and down. So obviously the torque will vary through the driveshaft's revolution.
The setup is as follows: Motor - couplings - torque transducer - couplings - pump.
The problem I have is that the couplings are fairly heavy and obviously themselves require torque to be driven round with the pump, and the information I want is the PUMP's drive torque, not the pump plus couplings. The couplings are all symettrical so their drive torque shouldn't vary through the revolution of the driveshaft, and the transducer doesn't offer too much resistance. I have or can obtain the rotational inertia for each coupling, I am just wondering how I translate this inertia into a resistive torque so I can subtract this number from the torque readings I obtain. The torque will be measured at a set of constant rotational velocities.
Any help that I receive will be greatly appreciated.
Regards,
David
If the motor runs at a fixed speed then the couplings will not be changing speed and so there will be no torque needed to cyclically accelerate and decelerate them. Only when there is some rotational slack in the couplings will a cyclic torque be required to rotate the couplings.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
