Purpose of a voltage follower (buffer)?
  • Thread starter Thread starter lamba89
    Buffer Voltage
A voltage follower, or buffer, is characterized by its nearly infinite input impedance, allowing it to connect to a signal source without loading it down, thus preserving the original signal. This makes it ideal for applications where signal integrity is crucial, such as in sensor interfacing and audio processing. The discussion also touches on the concept of a current follower, which is confirmed to exist and is typically designed with low input impedance. Participants emphasize the importance of prior research on the topic to foster more informed discussions. Understanding these concepts is essential for effective circuit design and signal management.
lamba89
What are the applications of a voltage follower?
Probably the most important characteristic of a voltage follower is that it has almost infinite input impedance. This means that when you connect a signal to its input, the source of the signal is not loaded down and the source won't even notice it has something connected to it, almost like an open circuit. So the voltage follower is able to reproduce the signal from the source to its output without the problem of changing the original signal by drawing current from it.
is there a current follower? and if so, should it have a low input impedance? Thanks.
Hopefully you did at least the minimum reading at wikipedia and other basic websites before posting this open-ended question here. What did you learn from that research, and what are your specific questions that you still have after that reading? Please provide links to what you don't understand yet.
Yes, and yes.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
