Pushing a block question (Friction)
  • Thread starter Thread starter Chandasouk
    Block Friction
The discussion focuses on a block on a table with static and kinetic friction coefficients. In Part A, the friction force is zero when the block is at rest. For Part B, the force required to initiate movement is expressed as the product of the static friction coefficient and the weight of the block. In Part C, pushing with half the force needed to move the block results in a friction force equal to the applied push, but the exact expression in variables is unclear. Finally, in Part D, once the block is in motion, the acceleration is determined by the kinetic friction force divided by mass, leading to the conclusion that acceleration equals the kinetic friction coefficient times gravity.
Chandasouk
A block of mass m lies on a horizontal table. The coefficient of static friction between the block and the table is \mus. The coefficient of kinetic friction is \muk, with \muk < \mus.
Part A
If the block is at rest (and the only forces acting on the block are the force due to gravity and the normal force from the table), what is the magnitude of the force due to friction?
Part B
Suppose you want to move the block, but you want to push it with the least force possible to get it moving. With what force F must you be pushing the block just before the block begins to move?
Express the magnitude of F in terms of some or all the variables mu_s, mu_k, and m, as well as the acceleration due to gravity g.
Part C
Suppose you push horizontally with half the force needed to just make the block move. What is the magnitude of the friction force?
Express your answer in terms of some or all of the variables mu_s, mu_k, and m, as well as the acceleration due to gravity g.
Part D
Suppose you push horizontally with precisely enough force to make the block start to move, and you continue to apply the same amount of force even after it starts moving. Find the acceleration a of the block after it begins to move.
A: 0
B: \mus * mg
C: I know the magnitude of the frictional force is equal to the\horizonatal push but I don't know how to express that in variables
D: I am clueless on this one
The frictional force is a self adjusting force. When it pushed with half the maximum frictional force, the body will not move. So the frictional force = ...?
For last part use μk.
1/2\mus * mg ?
Yes.
For part d, it is just \muk?
No.
a = frictional force/mass.
So, it is \muk/m since after you start moving the block, you are using \muk and no longer \mus
Frictional force is μk*mg
Mastering Physics says The correct answer does not depend on the variables: m, m, \muk.
Yes.
See what you get.
I did \muk * mg/m = a but it said The correct answer does not depend on the variables: m, m, \muk.
Acceleration is μk*g.
You can it as (Fr/N)*g
