QM Weinberg Probl 9.1: Solving for Eq of Motion with Defined Lagrangian
Kyueong-Hwang
specific lagrangian is defined.
Have to get a equation of motion
[/B]
Lagrangian is defined as
[/B]
eq of motion that i drive like
i guess term of f(x) have to vanish or form a shape of curl.
but it didn't be clear.
May i did something wrong but i can't catch that...
Hello Kyueong-Hwang, :welcome:
I find it hard to read what you write after | )
You want ##\partial {\mathcal L}\over \partial x_i## so I expect to see a ##\partial x_i## in the denominator, not ##\partial x_i \; f(\vec x)## ?
Time to learn some ##\LaTeX## (item 7 here) !
Likes Kyueong-Hwang
$$ \frac {\partial \mathfrak {L}} {\partial x_i} =\frac {\partial \vec x} {\partial t} \cdot \partial x_i \vec f \left(\vec x \right) - \partial x_i V \left(\vec x \right)$$
$$ \frac {\partial} {\partial t} \left(\frac {\partial \mathfrak {L}} {\frac {\partial x_i} {\partial t}} \right)= m \ddot x_i + \vec \nabla f_i \left(\vec x \right) \cdot \frac {\partial \vec x} {\partial t}$$
I thought ##\LaTeX## is hard to do.
But its quite fun XD
so. with these eqs we can make euler-lagrangian, eq of motion.
I guess changing index i in ##x_i## to ##\vec x## yield that vanish or assemble terms of ##f \left(\vec x \right)##
if ##x_i## is a axis of 3-dim cartesian coordinate two ##f \left( \vec x \right)## terms yield ##\vec \nabla \times \vec f \left(\vec x \right)##
But there is no such statement assure that ##x_i## is 3-dim cartesian coordinate.
And someone in this forum site says in higher than 3 dimension curl is hard to define.
also on wiki only 3, 7 dimension define curl
$$\frac {\partial \mathfrak {L}} {\partial x_i} =\dot{ \vec x_i} {\partial f_i \left(\vec x \right)\over \partial x_i } - {\partial V \left(\vec x \right)\over \partial x_i }$$
don't write$$
\frac {\partial} {\partial t} \left(\frac {\partial \mathfrak {L}} {\frac {\partial x_i} {\partial t}} \right)$$for two reasons: 1. it is ##d\over dt##, not ##\partial\over \partial t##, and 2. this way you will mix up ##x_i## and ##\dot x_i## -- they should be treated as independent variables !
So $$
\frac {\partial \mathfrak {L}} {\partial \dot x_i} = m\dot x_i + \vec f_i(\vec x)$$
Curl doesn't appear here.
alright thanks
1, at latex q&a page i miss d notation so i use partial
2. \dot \vec x isn't work so i think x_i does too
ah
your right. my fault.
is there any way to make this eq more clear?
next question is to make hamiltonian and find Schrodinger eq.
It may should be more clear.
Well, if ##\vec f(\vec x)## is time independent, you get ##m\ddot x = ... ##
Re Schr eq:
Please post a clear and complete problem description. For a different exercise, start a different thread.
