Quadcopter or drone robots designing
Quadcopters and drones have gained popularity due to advancements in propeller design, motor efficiency, and battery power, which enhance their lift capabilities. The lift generated by the propellers relies on their angular velocity, which is crucial for maintaining stability and control during flight. Innovations in software have simplified the flying experience, allowing users to control drones easily without needing extensive piloting skills. The ability to hover and maneuver with minimal effort has made drones accessible to a broader audience. Overall, the combination of improved technology and user-friendly design has contributed significantly to the rise of quadcopters and drones.
rajrocks
Hello everyone !
Its very first post here & with the go i want to know about basic reasons behind the liftup of quadcopters or drone going popular these days.
Is it
the propeller designing
motor weight & speed
battery power
etc ??
please explain :smile:
rajrocks said:
Hello everyone !
Is it
battery power
etc ??
Welcome to the PF.
It helps us a lot if we know what reading and research you've done so far. Can you post links to reading you have done so far, and ask specific technical questions about that reading? Thanks! :smile:
no nothing :biggrin: i just read about various propeller designs
some are making it with soft drink cans & so & so
i saw parrot AR prop.
I got so many things on net but want to know about deep theoritical designings
I have once fabricated (not designed but yet I had to analyse the given blueprint) a qaudrotor. In our design, it is the propeller design and rotation which is responsible for the lift. The lift generated depends on the angular velocity (## \omega ##) of propellers. This lift is mainly due to the reaction forces applied by air on propellers when the propellers push air downwards. The ## \omega ## of the propellers are set as such that the angular momentum of the system is conserved with respect to it's centre of gravity and your quadrotor is in rotational equilibrium. This results in lifting off of the quadrotor. You simply have to maintain the ## \omega ## if you wish to keep your device at a certain height. ## \omega ## depend on the configuration of motor and battery employed in your device and this angular velocity (of each propeller) can be varied. (all you need is a transceiver set-up and a little knowledge of coding). Now by varying this ##\omega ## you can tilt your quadrotor in desired direction (pitch, roll or yaw) and the movement is taken care of by the reaction forces. For example if you wish to move your quadrotor forward, all you need to do is set the angular velocities such that the quadrotor tilts in forward direction (pitch down) and the reaction forces from air will push your quadrotor forward.
rajrocks said:
Hello everyone !
Is it
battery power
etc ??
Apropos, today's WSJ has an article and interview with the "father of [copter] drones", explaining the innovations that made the popular
http://www.wsj.com/articles/a-consumer-drone-pioneer-were-learning-as-we-go-1428511868
WSJ: Model aircraft have been around for decades. How are drones different? Why have they become popular?
Mr. Muñoz: The complexity of a model helicopter is massive. A human cannot independently control four motors and try to balance them and be able to fly forward. Impossible. They’d crash. Drones transfer this mechanical complexity to the software. The software is doing all the difficult tasks of sensing and orientation in trying to stabilize it.
Normally, flying a model helicopter, you’re trying to keep it stable. A drone stays there for you, and you just tell it, like a videogame, move right or move left. Now a lawyer, a doctor, anybody can fly it.
It's a huge subject covering many different sciences.
To hover the rotor(s) must generate as much lift as the drone weighs. To do that they must accelerate air downwards (F=m*a). They can do that with a large slow rotor or a small high speed rotor. In general large blades are more efficient than small ones which is why real helicopters use relatively few large blades not lots of small ones. Model drones are probably relatively inefficient.
They are popular because they are a lot easier to fly than a conventional model helicopter. Most/many use contra rotating blades so that the pilot doesn't have to deal with the changing torque reaction that a helicopter pilot has to manage.
Thread 'I need a concave mirror with a focal length length of 150 feet?'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
