- #1
Nienstien
- 14
- 0
Ok, the problem is you have a 30cm wire, you cut it in two and you make one into a square. The second part is a rectangle with a 2:1 side ratio. I need to find the perimeter of each of the two shapes if the outcome sum of areas were to be a minimum.
I did all the algebra and such spent about 2 hours logically trying to crack this problem then I figured I had to make some sort of quadratic function.
I just about thought I was finished when I had these two functions:
A(square)=L(square)^2
A(rectangle)=1/2L(rectangle)^2
So from this I figured in order to have a minimum area i must put ALL of the wire into the rectangle however that is not the case. My teacher says that this must be proven.
I think the answer has to do with:
30=L(wire)=P(square)+P(rectangle)=4L(Square)=3L(Rectangle)
Any suggestions?
I don't necessarily want the answer as much as I would like to understand this kind of problem. I'm in grade 10, thanks.
