MHB Can a Golfer's Shot Be Modeled by a Quadratic Equation?
  • Thread starter Thread starter Abdullah Qureshi
    Quadratic Relation
The golfer's shot can be modeled using the quadratic equation h = -0.01875x^2 + 2.25x, where h represents the height of the ball and x is the horizontal distance from the shot's origin. To determine if the ball clears the tree, the height at x = 40 yards must be calculated. The maximum height of the ball can be found by analyzing the vertex of the quadratic equation. The discussion emphasizes the importance of showing work for each calculation to receive constructive feedback. Overall, the thread focuses on applying quadratic equations to real-world golfing scenarios.
Abdullah Qureshi
A golfer hits a tee shot into the rough and the ball stops approximately 120 yds from the green. There is a tree located 40 yds from the ball, directly in the path of the shot. The golfer decides to try to hit the ball over the tree. The path of the shot can be modeled by the equation h = -0.01875x2 + 2.25x, where h is the height of the ball and x is the horizontal distance in yards from where the second shot is taken. (6T/I, 2C)
i) How tall must the tree be to stop the ball?
ii) Does the golfer hit the green with the shot?
iii) What is the maximum height of the ball and when does it occur
Mathematics news on Phys.org
in future, use the caret symbol (^) to indicate an exponent
i) This one is simple ... what value should you use for x?
ii) let x = 120 ... what do you get for h? what does that value tell you?
iii) the solution to ii) should help you determine the max height
You understand that ''like" really means "Blast, Skeeter got to it before I did!"
What is the answers
Abdullah Qureshi said:
What is the answers
You really need to show some effort by posting your work on each question, that way we can provide feedback as to where you are right or wrong.
I will not provide "answers".
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
